Ontario Home Renovation Grants and Rebates in 2026: What GTA Homeowners Can Actually Claim
Most homeowners doing renovation work in Ontario in 2026 are leaving money on the table. Between federal programs, provincial incentives, and municipal subsidies, there is meaningful money available - but it is spread across three levels of government, the programs keep changing, and missing one step in the application sequence can disqualify you from a rebate that was yours to take.
Here is a plain-language rundown of what is actually available right now, focused on what GTA homeowners can realistically access.
Federal: Canada Greener Homes Loan
The federal government relaunched this program after pausing it in 2023. It offers interest-free loans up to $40,000 for energy efficiency upgrades including heat pumps, insulation, windows and doors, and air sealing. Repayment is over 10 years with no interest. The key requirement is a pre- and post-upgrade energy audit through a registered NRCan assessor - budget $400-600 for each audit. The audit must happen before work starts, which catches a lot of homeowners off guard.
Current status and eligibility: canada.ca/greener-homes. These programs change without much notice, so verify before planning around them.
Federal: GST/HST New Housing Rebate
If you are doing a substantial renovation - generally defined as gutting and rebuilding at least 90% of the living space - the CRA considers it equivalent to new construction for tax purposes. That means a partial rebate of the GST/HST paid on materials and labour. On a $150,000+ full-home renovation the rebate can reach $30,000 or more. Talk to your accountant before the project finishes, not after - the documentation requirements start at the planning stage.
Provincial: Home Renovation Savings Program (Ontario)
Ontario runs a parallel program targeting insulation, air source heat pumps, smart thermostats, and related upgrades. The structure combines upfront product rebates and, for lower-income households, a top-up. Base rebates are available regardless of income.
Funding levels have shifted as federal and provincial programs overlap and renegotiate. Confirm the current structure at ontario.ca before booking any work.
City of Toronto: Basement Flooding Protection Subsidy
The most immediately actionable program for GTA homeowners right now. The City of Toronto is raising this subsidy to $6,650 effective May 1, 2026 - that is this week. It covers backwater valve installation, window well drain installation, sump pit and pump installation or upgrade, and downspout disconnection.
If you have had any basement moisture this spring, the timing window matters. Full details on costs, qualifying work, and how to apply: Toronto Basement Flood Subsidy Jumps to $6,650 on May 1.
City of Toronto: Home Energy Loan Program (HELP)
A separate Toronto program for energy retrofits. It provides financing (not a grant) for energy improvements at a fixed rate, repaid through your property tax bill over 5-10 years. Useful if you want to do deeper energy upgrades but do not qualify or want to wait for the federal program. toronto.ca/HELP for current rounds.
The Sequencing Problem
This is where most homeowners miss out. Programs have order-of-operations requirements that are easy to overlook:
  1. Some require a pre-work energy audit before anything starts.
  2. Some require the contractor to be pre-registered on a program list.
  3. Some have application windows that close before the project is done.
  4. Municipal and provincial programs sometimes cannot both be claimed on the same work - check the stacking rules.
The fix is simple: before you call anyone for a quote, spend 30 minutes identifying which programs could apply to your project, then call the program office to confirm sequencing. It is worth the time.
If you have a specific project in mind - kitchen, bathroom, basement, HVAC - drop it in the replies and I will point you toward what is actually available for that type of work. LF Builders has been doing this work across the GTA for over 50 years and we have navigated these programs with many homeowners. Happy to help sort through it.
  • BuildersLTD
Related: Most Commonly Asked Questions | GTA Lumber Prices Climbing This Spring
Frequently Asked Questions
Q: What government grants and rebates are available to GTA homeowners for renovations in 2026?
The most significant programs currently active: Save on Energy’s Home Rebate Switch (rebates on qualifying heat pumps, smart thermostats, and insulation); Enbridge’s Home Efficiency Rebate Plus (up to $10,000+ on qualifying heat pump systems); and the Toronto Basement Flooding Protection Subsidy (now $6,650 as of May 1, 2026 for backwater valves, sump pumps, and severance of downspout connections). The Canada Greener Homes Grant is closed to new applicants in most regions. CMHC’s MLI Select program remains relevant for homeowners adding a secondary suite. Always confirm current program availability directly with the administering body — programs open and close with limited notice.
Q: How does the Toronto Basement Flooding Protection Subsidy work in 2026?
The subsidy covers up to $6,650 (as of May 1, 2026, increased from $3,400) for eligible work including backwater valve installation, sump pump installation with battery backup, and severance of downspout connections to the sewer. The work must be done by a licensed contractor, inspected by the City, and the subsidy is applied after the work is complete and verified — you pay the contractor upfront and the City reimburses after inspection. Eligible properties are residential homes connected to the City’s combined or partially-combined sewer system. See the companion guide: GTA Backwater Valve Installation 2026.
Q: Does the Canada Greener Homes Grant still apply to GTA renovation projects in 2026?
The Canada Greener Homes Grant for individual homeowners closed to new applicants in 2024 and is no longer available for most GTA homeowners starting a new application in 2026. Homeowners who had an accepted application before the program closed may still be in-process. The replacement landscape is the provincial Save on Energy and Enbridge HER+ programs, which collectively cover many of the same upgrade categories (insulation, heat pumps, windows, doors) with comparable or better incentives in some categories. Check saveonenergy.ca and enbridge.com/HER for current eligibility.
Q: How do I apply for renovation rebates in Ontario without missing deadlines?
The practical approach: before any project starts, list every category of work in the scope and cross-reference against Save on Energy, Enbridge HER+, CMHC, and municipal programs (Toronto Basement Flooding Protection Subsidy, Green Homes grant at the municipal level in some GTA cities). Most programs require a pre-approval or registration step before the work begins — retroactive applications are not accepted by most programs. An energy advisor or a rebate aggregator service can run this check in 30 to 60 minutes; for a $50,000 renovation, the rebate research investment is almost always worth the time.
One more rebate worth adding to the stack before homeowners finalize spring scope, because the deadline lands this week.
Toronto’s Basement Flooding Protection Subsidy is nearly doubling on May 1, 2026, from $3,400 to $6,650 per property. The cut-off is for eligible work completed on or after November 12, 2025, so if you have already had a backwater valve, sump pump, or downspout disconnection done in the last six months, the reimbursement is back-dated to that date. The new program also adds a $300 line item specifically for sump pump battery backup retrofits, which is small money individually but matters because the 2024 storm season had hundreds of GTA basements flood specifically because the power cut out at the same moment the rain peaked.
A few practical notes on how this one stacks with the federal and provincial side, since this is where homeowners get tripped up on the order of operations:
  • Order of operations matters. The basement flood subsidy is a Toronto Water program and reimburses after the work is done, no pre-audit. Greener Homes and HRS rebates need a pre-retrofit and post-retrofit audit booked first. If you do flood work and skipped the energy audit, you cannot back-fill it later.
  • Permit pull cost has moved against you. Toronto raised base permit fees 4 percent on Jan 1, and trade permits run $445 to $1,020 each on plumbing, HVAC, or electrical work over $5K. Factor those into the budget before you compare net rebate value.
  • The Multigenerational Tax Credit ($7,500) only triggers if the suite has its own bath, kitchen, and entrance, and is occupied by a qualifying senior or disabled relative. It is not stackable with the basement flood subsidy on the same labour costs.
Full thread on the May 1 subsidy doubling here for anyone who wants the application paperwork side: Toronto Basement Flood Subsidy Jumps to $6,650 on May 1
If anyone is mid-quote this week and wondering which programs to apply for in what order, drop the rough scope and I will walk through the sequencing.
