GTA Sunroom and Three-Season Room Spring 2026: Aluminum vs Hybrid Frames, Foundation Reality, and Real Costs by Type
Sunroom inquiries spike in the GTA every spring, and 2026 is no different — the post-pandemic outdoor-living surge has not dissipated, the cost of a finished interior addition has gone the other way, and an aluminum-framed sunroom now reads to a lot of homeowners as the most affordable way to add real, weatherproof square footage to a home. The questions in our inbox are mostly the same five every year. Three-season or four-season? Aluminum or wood? Slab or piers? Do I need a permit? And the one nobody asks until the demolition starts: what does the foundation actually look like under a deck I want to convert?
This thread is meant to be the one place to point homeowners considering a sunroom in spring 2026. It covers the build types, the price bands, the permit reality under the 2024 Ontario Building Code (which applies to all permits issued after 1 April 2025), the glazing and thermal-break specs that separate a real four-season room from a glorified screen porch with glass, and the contractor red flags we see every spring on the bid table.
Three-season vs four-season vs solarium — the real difference
The labels get used interchangeably and they should not be. They describe three different products with three different price brackets and three different scopes of permit and foundation work.
A three-season room is unconditioned space. The frame is typically aluminum or vinyl, the glazing is single-pane or basic dual-pane non-low-E, the floor is whatever the deck or slab beneath was, and the room is comfortable from roughly mid-April through late October in southern Ontario. There is no HVAC connection. No insulation in the walls or roof. No electrical beyond a couple of outlets and lighting. It does not count as conditioned floor area for resale purposes, but it does count as structure for setbacks and lot coverage.
A four-season room (sometimes called an “all-season sunroom”) is conditioned and built to be lived in year-round. Thermally broken aluminum frames, dual or triple-pane low-E argon glazing, insulated walls and roof where they are not glass, dedicated HVAC (almost always a ductless mini-split head these days — see GTA Ductless Mini-Split Spring 2026: Cold-Climate Models, Multi-Zone Sizing, Electrical Load Math, and Real Costs After Greener Homes Ended for the math on those), and a permanent foundation. This DOES count as conditioned floor area, which means it counts for property tax and for resale square footage but also for setbacks, lot coverage, and the OBC energy compliance path on the addition. Different rules entirely.
A solarium is a four-season room with a glass roof rather than an opaque insulated roof. They look spectacular and they perform worse — overhead glazing has the worst angle of incidence for both summer heat gain and winter heat loss, and the U-factors quoted on the wall units do not apply to the roof units. Premium solariums use heated glass or motorized exterior shades to manage the heat-gain-and-loss problem. Both options add five figures to the budget. We will not normally recommend a solarium for a homeowner who is cost-sensitive — the maintenance, condensation management, and long-run energy bill on a glass roof in southern Ontario is a different commitment than a four-season room with an insulated cap.
The four common sunroom build types
Prefab kit (DIY or contractor-installed). Aluminum extrusions, factory-glazed panels, ships flat to the site, assembles in 1-3 days on an existing deck or slab. Cheapest entry. Usually three-season only because the kit’s frame and glazing specs do not meet OBC energy requirements for conditioned space. Best for converting a covered deck into a screened-in or glassed-in three-season room. Typical kit price $8,000-$22,000 plus install if not DIY; total turnkey $15,000-$35,000 in the GTA.
Custom aluminum (manufacturer-engineered system). The category most “Four Seasons Sunrooms” or similar branded installs fall into. Aluminum frame with engineered thermal breaks, 5/8" or 3/4" insulated glazing units with argon and a low-E coating, factory-finished colour, choice of pitched or shed roof with EPDM membrane or insulated panel. Foundation is normally a thickened-edge slab or sonotube piers. Permitable as either three-season or four-season depending on glazing/insulation spec. Typical GTA installed cost $35,000-$95,000 depending on size, glazing tier, and roof type. This is the band most spring 2026 inquiries land in.
Stick-built/hybrid (conventional framing with large window units). Built like a normal home addition — wood-framed exterior walls with exterior cladding to match the house, but with high glazing-to-wall ratio achieved by ganged window units or a custom-fabricated wall system. Looks integrated with the house. Performs like a normal addition because it is one. Typical GTA installed cost $55,000-$140,000 depending on roof tie-in, finish level, and whether it includes plumbing for a wet bar or powder room. This is the only build type that consistently appraises as a full-value home addition rather than at the discounted “sunroom” rate.
Conservatory/glass-roof solarium. Glass roof, often with structural mullions. Premium product, premium install. Typical GTA installed cost $85,000-$180,000+. Specifies dedicated HVAC strategy, exterior shading, and condensation management.
Real GTA spring 2026 costs by type and size
Numbers below are turnkey installed for a standard rear-yard install on level grade, assuming average access. Add 10-25% for steep grade, complex tie-ins to existing roof lines, second-storey integration, or limited site access (typical Toronto narrow lots and downtown semis).
A 10x12 prefab three-season kit on existing deck — $18,000-$28,000. A 12x16 custom aluminum three-season on new sonotube piers — $32,000-$48,000. A 12x16 custom aluminum four-season on slab with mini-split — $58,000-$82,000. A 14x20 custom aluminum four-season with shed roof, slab, and mini-split — $78,000-$110,000. A 14x20 stick-built four-season addition with brick or fibre-cement to match house, full HVAC tie-in, OBC energy-compliant insulation, and matching roof line — $115,000-$165,000. A 12x16 conservatory with insulated glass roof, motorized shades, and dedicated HVAC — $130,000-$180,000.
For a member-side reality check on what a real GTA build looks like end to end, the Sunroom addition on our Burlington home — three-season room, permit process, full cost breakdown thread documents one homeowner’s actual numbers, photos, and timeline through their municipal permit process — useful companion reading because most online price guides give you a brand quote without the line items underneath.
Permit reality — when you need one, what the OBC and your bylaw actually require
Almost every sunroom build in the GTA needs a building permit. The exceptions are narrow: a removable seasonal screened-in canopy under 10 m² that is not anchored to the structure, or an exempt accessory structure under specific zoning categories (rare for residential use). Anything that is anchored to the house, has a glazed wall, or has an enclosed roof needs a building permit and almost always needs OBC-compliant structural drawings.
Setbacks and lot coverage are where most homeowner plans get blocked. Side-yard setback in Ontario for a residential addition is typically 1.2 m minimum (your municipal zoning bylaw can be tighter — Toronto’s R-zones often require 1.5 m or more). Rear-yard setback minimum is typically 7.5 m for a primary structure but lower for accessory structures depending on the bylaw. Maximum lot coverage is the killer in built-up Toronto neighbourhoods — many R-zones cap lot coverage at 33% or 35%, and a homeowner with an existing footprint over the cap cannot add a sunroom without a Committee of Adjustment minor variance or going to the Toronto Local Appeal Body. Always check zoning before you commit to a quote — a contractor who tells you “we will worry about the permit later” is offering to start a project they cannot finish legally.
The 2024 Ontario Building Code applies to all permit applications submitted after 1 April 2025, which means every spring 2026 application falls under the new code. Practical impact: stricter energy compliance for conditioned additions (your four-season room must meet the same SB-12 prescriptive package or NECB performance path as a normal addition), tighter glazing-to-wall ratios for the prescriptive path, and clearer documentation requirements on thermal-break specs for aluminum-framed conditioned space.
For Toronto specifically, the typical sunroom permit timeline is 8-14 weeks from complete application to issued permit (faster if you qualify for FASTRACK on the simpler addition path, slower if Committee of Adjustment is in the loop). Outside the city of Toronto, smaller GTA municipalities are usually 4-8 weeks. The application package needs site plan, foundation plan, framing/structural drawings stamped by an Ontario P.Eng. for anything other than the simplest prefab kit, energy compliance documentation if conditioned, and zoning compliance review.
Aluminum frame and glazing specs that actually matter
The single biggest difference between a $35K three-season and a $75K four-season install is the thermal break and the glazing. Read the spec sheet, not the brochure photo.
Aluminum is a structural metal that conducts heat about 1,400 times better than wood. An un-broken aluminum frame in a Toronto winter is a giant thermal bridge — the frame face on the inside will sit at or near outdoor temperature on a -15°C day and condense water on every interior surface. A thermally broken aluminum frame inserts a polyamide thermal break (typically a 24-44 mm strip of glass-fibre-reinforced nylon) between the inner and outer aluminum profiles, breaking the conduction path. That single change drops the frame’s U-value from roughly 5.7 W/m²·K (un-broken) to 2.8-3.4 W/m²·K (broken), and matched with the right glazing the whole-window U-value can land at 1.4-1.8 W/m²·K — meeting or beating Ontario’s SB-12 requirements for a conditioned addition.
For a four-season room in southern Ontario, a workable glazing spec looks like dual-pane 22 mm IGUs (insulated glass units) with one or two low-E coatings, argon fill, and a warm-edge spacer. Whole-window U-factor target ≤1.6 W/m²·K, ER (Canadian energy rating composite) ≥ 30 on east/west exposures and ≥ 35 on north exposures (south can run lower because the SHGC works for you in winter — but you will need exterior shading in summer or the room overheats). Triple-pane is overkill for most GTA sunroom applications outside a north-facing exposure or a high-design spec with the budget to support it.
For a three-season room in southern Ontario, the spec relaxes — non-thermally-broken aluminum is acceptable, single-pane glazing or basic dual-pane is fine, the room is meant to be empty in winter. The trap is contractors who quote you a three-season frame and try to upsell you to a four-season experience without ever upgrading the spec. Glassing in an unheated aluminum frame and adding a space heater is not a four-season room. It is a glassed-in patio with a power bill.
Foundation options — what’s under it matters more than what’s on it
Three sound foundation strategies for a GTA sunroom, in order of cost.
Existing deck retrofit. If the existing deck has a footing system rated for the additional load (a sunroom’s dead load is typically 25-35 lb/sq ft above the deck’s design dead load, plus a snow live load of 32 lb/sq ft for the GTA), and if the joists and ledger can carry the new live load, a prefab kit can sit on top of the existing deck. The catch is that most Toronto-area decks built in the 2000s and earlier were built to 10-15 lb/sq ft dead load and cannot legally carry a sunroom — your structural engineer will require either a footing upgrade to helical piers underneath, sistered joists, and a new ledger flashing, or a teardown-and-rebuild. Honest cost on a deck retrofit when the deck does not pass the load check: $8,000-$22,000 of structural work BEFORE you start the sunroom.
Sonotube piers. Concrete-filled tube piers extending below the GTA frost line of 1.2 m. Code-minimum diameter for residential sunroom posts is 254 mm (10") with a 600x600x200 mm bell footing at the base. Typical cost in the GTA is $400-$650 per pier installed, and a 12x16 sunroom typically needs 6-8 piers. Total $2,400-$5,200 in foundation work, plus the post-and-beam framing on top. Common foundation choice for three-season builds because it is the cheapest code-compliant option.
Slab foundation (thickened-edge or full perimeter). Required for most four-season builds and for any sunroom whose roof ties directly into the house wall. Thickened-edge slab with 4 ft frost wall around the perimeter, insulation under the slab and on the inside of the frost wall, in-floor radiant or ductwork chase if the design includes it. Typical GTA installed cost $7,000-$18,000 depending on size, soil conditions, and whether existing landscape needs to be removed.
Frost-protected shallow foundation (FPSF) — code-allowed under the 2024 OBC for heated structures with continuous foundation insulation, and a real cost-saver in some cases (foundation depth as shallow as 400 mm with proper insulation strategy). Less common in GTA residential because most local building departments are still more comfortable with full-depth frost walls, but viable. Get an Ontario P.Eng. drawing if you go this route.
The decision tree is simple. If the room is three-season and the deck passes the structural check: deck retrofit with a kit. If the room is three-season and the deck does not pass or there is no deck: sonotube piers. If the room is four-season: slab with frost wall (or FPSF if your engineer recommends it). Anyone offering you a four-season build on sonotube piers is offering a code violation.
Heating, cooling, and the rebate landscape
A 12x16 four-season sunroom in southern Ontario has a design heat loss of roughly 6,000-9,000 BTU/h in winter and a peak cooling load of 8,000-14,000 BTU/h in summer (the cooling load is usually higher than the heating load on south or west exposures because of solar heat gain through the glazing). The standard answer is a single ductless mini-split head sized at 9,000-12,000 BTU/h, mounted high on the wall opposite the glazing, on its own dedicated electrical circuit. Total mini-split cost installed is typically $4,500-$7,500 and pulls electrical load that is well within most existing 200A panels.
If you are in the rebate-planning phase, the Ontario Home Renovation Grants and Rebates in 2026: What GTA Homeowners Can Actually Claim thread covers the current state of the Home Renovation Savings Program, the closure of the federal Greener Homes Grant in late 2025, and where the leftover federal Greener Homes Loan still helps. Sunrooms themselves are not a directly rebatable line item, but the heat-pump head and the high-efficiency glazing on a four-season build are both eligible under the Save on Energy HRS program at the time of writing.
For homeowners weighing a sunroom against a less-committed outdoor option, GTA Retractable Awnings and Outdoor Shade Spring 2026: Manual vs Motorized vs Fixed Aluminum, Real Costs and What Survives Toronto Wind is the related thread on covered-but-not-enclosed alternatives — useful if your real need is shade and weather protection rather than year-round conditioned space.
A few things we see every spring on bid review.
“We can install in two days, no permit needed.” Almost always means the company plans to install a kit anchored to your house without a permit. Your insurer will not cover a non-permitted addition if it leaks or fails. The next owner’s home inspector will find it and the deal will price-adjust or fall apart. Walk away.
A four-season quote that does not specify the U-factor of the glazing or the thermal-break depth of the frame. You are buying a house in winter without asking how the heat is going to stay in. A real four-season quote names the IGU spec, the low-E coating count, the gas fill, the spacer material, and the frame thermal break depth in millimetres.
Foundation method “to be determined on site.” A real bid has either a slab spec or a pier spec with diameter, depth, and count. “We will see what is there” is how foundation costs balloon $5,000-$15,000 mid-project.
No structural drawings, or drawings that are not stamped. A 12x16 sunroom with a glazed wall system is a structure that needs an Ontario P.Eng. stamp on the drawings for permit purposes, full stop. Drawings from the manufacturer are not always stamped for Ontario unless the manufacturer is licensed here. Confirm before you sign.
Cash-only or “we’ll discount 20% if you pay cash.” Tax fraud risk for both parties. The HST on a $60,000 sunroom is real money but underground-economy pricing is how warranty claims disappear. Pay through normal channels and keep the paperwork.
A promise to match an existing roof line “for free.” Roof tie-in to an existing slope is among the most consequential structural and weatherproofing details on a sunroom build. It is not free. If it is being given away, the cost is buried elsewhere or it is being skipped.
Bottom line for spring 2026 GTA homeowners
A sunroom is a real addition, not a glassed-in patio, and the difference between a three-season and a four-season build is not branding — it is foundation, frame, glazing, HVAC, and permit scope. The honest 2026 GTA price bands are $18K-$48K for three-season, $58K-$110K for custom aluminum four-season, and $115K-$165K for stick-built four-season that appraises as a real addition. Sonotube piers are fine for three-season; four-season needs slab or engineered frost-protected shallow foundation. Glazing U-factor below 1.6 W/m²·K and a real polyamide thermal break in the aluminum frame are the two specs that separate a winter-comfortable room from a winter-condensation problem. Permit is non-optional in nearly all cases, and the 2024 OBC tightened the energy compliance path for conditioned additions in spring 2025. Most importantly, get the structural drawings stamped by an Ontario P.Eng., get the foundation method named in the bid, and walk away from any contractor whose quote skips those line items.
Track $RENO earnings on this topic — top contributors at the GTA-homeowner-and-trades intersection are tier-up candidates. If you have built or quoted a sunroom in the GTA in the past 12 months, post your numbers, your foundation method, your IGU spec, and any photos of the roof tie-in or the slab pour — those are the details other homeowners cannot find anywhere else online. New here? Read Welcome to $RENO — Quests, Rewards, Leaderboard and link a Solana wallet on signup so any future on-chain settleme
More from LF Builders & home.renovation.reviews
LF Builders has served the Greater Toronto Area for over 50 years with more than 30,000 completed renovation and construction projects. From interlock and flagstone to full kitchen and bathroom renovations, waterproofing, and aluminum work — explore services and request a quote at lfbuilders.ca.
Samm Simon’s 251 KM Challenge for Cancer Research — LF Builders is proud to support Samm Simon’s 251 km charity run raising funds for cancer research. Follow the journey and donate at sammsimon.ca.
Further reading on the LF Builders blog: Comprehensive Home Renovation Trends: What GTA Homeowners Are Building — practical detail that pairs well with the topic above.
