Why Are Renovation Quotes So High in Spring 2026?
I have been in the trades in the GTA for over thirty years and I hear the same question every spring. This year it is louder than usual: “Why does my quote look so much higher than what my neighbour paid two years ago?”
The short answer is that the cost structure of a renovation has shifted in ways most homeowners are not expecting — and it has very little to do with lumber or drywall.
The Material Price Story Is Actually Flat
Here is what surprises most people when I explain it to them: the price of core materials like lumber, plywood, and standard finishes is sitting close to where it was in 2023. In some categories it is fractionally lower. If you went into this spring expecting a significant material cost premium because of general inflation, that expectation is off.
So why do the quotes look bigger?
Labour Is the Real Driver in 2026
The residential construction sector in Ontario finalized new collective agreements in mid-2025. The wage increases baked into those deals were substantial — close to 20 percent in some trade categories when you account for both base rate increases and benefit contributions. Those costs have now fully flowed through to what contractors are quoting.
This matters because labour is the dominant line item in most GTA renovation scopes. On a mid-range kitchen gut reno, labour typically runs 40 to 50 percent of total project cost. A 20 percent jump in that category alone moves the total quote by 8 to 10 percent before you factor in anything else.
The Carbon Tax Increase Nobody Is Talking About
The federal industrial carbon price hit $110 per tonne on January 1, 2026 — up from $80 the year before. That is a 37.5 percent jump in twelve months. Sawmills, treatment facilities, concrete plants, and the vehicles used to deliver to your job site all absorb that increase. It works its way into costs quietly but it is real.
Permit Fees Also Went Up
The City of Toronto increased its building permit fee schedule by 4.82 percent effective January 1, 2026. On a project that requires a permit — and more projects do than homeowners realize — this is a line item that your contractor is passing through to you at cost. It is not padding; it is what the City charges.
What This Means for You Right Now
If you are planning a spring or summer renovation, here is practical advice from someone who has been through several market cycles:
Get your quotes now, not in June. Contractors who are well-booked move their pricing up through peak season. The quote you get in late April is almost certainly lower than what you will see in July.
Ask for itemized quotes. A quote that just says “kitchen renovation — $65,000” tells you nothing useful. Ask for a breakdown by labour category, materials, permit fees, and contingency. If a contractor will not provide that, find one who will.
Your 2024 quote is not valid in 2026. If someone gave you a price eighteen months ago and you held onto it, it is likely 10 to 15 percent below what the actual cost is today. Plan your budget accordingly.
Compare three quotes minimum. The spread between the high and low quote on a significant project can be $15,000 to $20,000 in this market. Some of that reflects genuine quality differences. Some of it reflects how busy a contractor is. You need to understand which is which.
The Longer View
What I am seeing in the field is that homeowners who are moving forward in 2026 are generally those who made the decision to renovate for how they want to live — not to maximize short-term resale. That is a healthy instinct. The best work we do is for people who care about the outcome, not just the number on the appraisal.
If you are getting quotes this spring and the numbers are giving you sticker shock, drop a reply below. Sometimes talking through the scope line by line helps people figure out where the real cost is, and where there is room to adjust.
We also cover the full range of renovation permits and process questions over at home.renovation.reviews — worth bookmarking if you are in the early planning stages of a project.
— LF Builders, Toronto
Frequently Asked Questions
Why are renovation quotes so high in spring 2026?
Three converging factors: Ontario residential trade wage increases of up to 20% from 2025 collective agreements, a 37.5% jump in the federal carbon price (from $80 to $110/tonne), and a 4.82% Toronto permit fee increase effective January 1, 2026. Materials are largely flat — labour is the dominant driver.
How much did Ontario trade labour costs increase in 2026?
New collective agreements finalized in mid-2025 baked in wage increases close to 20% in some trade categories when base rates and benefit contributions are combined. Since labour typically accounts for 40–50% of a mid-range kitchen renovation, that alone adds 8–10% to the total quoted price.
Should I get a renovation quote now or wait until fall 2026?
Get your quotes now. Spring and summer are peak booking season — contractors who are well-booked typically increase their pricing through peak months. A late-April quote is almost certainly lower than what you will see in July or August.
How should I budget for a GTA renovation in 2026?
If you are working from a 2024 estimate, add 10–15% to account for labour and regulatory cost increases. Request itemized quotes that break out labour, materials, permit fees, and contingency. Compare at least three contractors before committing.
LF Builders has been completing GTA home renovations for over 50 years — get a current quote at lfbuilders.ca. LF Builders supports Samm Simon’s 251 km charity run for cancer research.
