Green renovation resources: heat pumps, Greener Homes, insulation rebates
Compiling the best resources for Toronto homeowners considering green/energy efficiency renovations.
Federal programs:
  • Canada Greener Homes Grant: up to $5,600 for heat pumps, insulation, windows (verify current availability — funding has had gaps)
  • Canada Greener Homes Loan: up to $40,000 at 0% interest for energy retrofits
Ontario/utility programs:
  • Enbridge Home Efficiency Rebate: up to $5,000 for switching to heat pump
  • Toronto Hydro rebates: periodic, check their website for current offers
What’s worth doing:
  1. Air seal and insulate FIRST (reduces heating load before sizing new HVAC)
  2. Cold climate heat pump (Mitsubishi Zuba, Bosch, Daikin work at -25°C)
  3. Upgrade windows if original single-pane
The full green renovation guide is at Toronto Green Renovation Guide: Heat Pumps, Insulation and Grants 2026 – Telegraph
Has anyone completed a heat pump installation recently? What did you pay, which brand, and how has the first winter gone?
How to Access Green Renovation Incentives in the GTA: Step-by-Step
Before you commit to any green renovation project, there are four practical steps that determine whether you actually receive rebates or not. Most homeowners skip step 1 and lose eligibility for programs that require pre-approval.
Step 1: Book a pre-retrofit energy assessment before any work begins.
Canada Greener Homes and most provincial programs require a registered energy advisor to assess your home before and after upgrades. This is not optional — without a pre-assessment, your post-project application is ineligible. Budget approximately $400–600 for the two visits (some programs subsidize this cost).
Step 2: Cross-reference your planned scope against current program availability.
The Canada Greener Homes Grant has had funding gaps — verify it is accepting new applications at the time you are reading this. The Greener Homes Loan (up to $40,000 at 0% interest) has generally been more stable. Enbridge HER+ (up to $5,000 for heat pumps) is available to Enbridge customers only. Toronto Hydro rebates are periodic and worth checking directly at the time of project planning.
Step 3: Sequence upgrades in order of energy impact.
Air sealing and insulation come first — they reduce the heating and cooling load that your new HVAC system will serve. Installing a cold-climate heat pump in a leaky house is sizing it for the house you have, not the house you are creating. Doing insulation and air sealing first means a smaller, cheaper, properly-sized heat pump.
Step 4: Confirm contractor eligibility for rebate programs before signing.
Some programs require that the installing contractor is registered or certified for the rebate to flow. For heat pumps under certain utility programs, this matters. Verify before contracts are signed, not after.
Good roundup. A few practical additions from what we’ve been seeing on the ground in the GTA this year.
The Grant vs. the Loan — know which one is live. The Canada Greener Homes Grant has had funding gaps and was wound down federally in early 2024. What’s still fully active is the Canada Greener Homes Loan — up to $40,000 at 0% interest for 10 years. That’s genuinely good money for a heat pump or deep retrofit. If someone tells you they can get you the Grant, ask them to show you the current program page.
EnerGuide audit is the gatekeeper. You cannot access federal programs without a pre-retrofit EnerGuide audit done by a registered energy advisor. Right now in the GTA, wait times are running 6-8 weeks for a qualified auditor. Book the audit before you book the contractor — not after. Too many homeowners get surprised by this.
Real numbers for heat pump installs in 2026. A properly sized cold-climate heat pump (Mitsubishi Zuba-Central, Bosch, or Daikin Fit) installed in a typical GTA semi-detached runs $12,000-17,000 all-in before incentives. After stacking the Enbridge rebate ($5,000 for heat pump switches) and the Greener Homes Loan, your net out-of-pocket can drop to the $6,000-9,000 range — and you’re replacing your furnace at the same time. The math works, especially with gas prices where they are.
Air sealing first — always. The guide above nails this. We’ve seen clients install $15K heat pumps into poorly sealed houses and still have high bills. Seal the attic hatch, rim joists, and pot lights before sizing HVAC.
Anyone here have a heat pump installed in the GTA already? Would love to hear how the first winter went — especially on the coldest days.
