GTA HVAC 2026: Heat Pump vs. Furnace, Rebates, and Contractor Costs
HVAC replacement is a major decision for Ontario homeowners in 2026. Heat pumps, high-efficiency furnaces, and central AC each have different costs, rebates, and performance profiles in the GTA climate.
Heat Pumps in Ontario 2026: Are They Ready?
Cold-climate heat pumps (Mitsubishi Hyper-Heat, Bosch, LG) now operate efficiently to -25C, making them viable across all of Ontario. The Canada Greener Homes Grant (up to $5,000) + Enbridge incentives make heat pumps cost-competitive with gas furnace replacements in 2026. Dual-fuel systems (heat pump primary, gas furnace backup) are popular in colder parts of Ontario.
Gas Furnace Replacement Costs
  • Mid-efficiency (80% AFUE): $3,500-$6,000 installed
  • High-efficiency (96% AFUE): $5,000-$8,500 installed
  • Variable-speed modulating (96%+ AFUE): $8,000-$12,000 installed
    Enbridge rebates up to $1,000 for qualifying high-efficiency upgrades in Ontario.
Central AC Replacement
  • 13 SEER2 standard efficiency: $3,500-$5,500 installed
  • 18+ SEER2 high efficiency: $6,000-$10,000 installed
  • Ductless mini-split (single zone): $2,500-$5,000 installed
For a deeper look at ductless mini-split sizing, multi-zone configurations, electrical-load math, and 2026 GTA install costs after the Greener Homes program ended, see GTA Ductless Mini-Split Spring 2026: Cold-Climate Models, Multi-Zone Sizing, Electrical Load Math, and Real Costs After Greener Homes Ended.
Spring 2026 GTA HVAC Market
Contractors are booking 4-8 weeks out for HVAC work. Get quotes now for spring/summer installation. Always verify TSSA certification for gas work in Ontario.
LF Builders connects homeowners with qualified GTA HVAC contractors: https://lfbuilders.ca
Share your HVAC upgrade experience at https://home.renovation.reviews
Related on the forum:
