Ontario Lally Column and Basement Beam Guide 2026 - Inspection, Replacement and Costs
Lally columns and steel I-beams are the primary structural support systems in most Ontario post-war homes. Deteriorated or improperly installed columns and beams are a structural safety concern requiring prompt attention.
Types of Support Columns in Ontario Basements
Lally columns (steel pipe columns): Hollow or concrete-filled steel pipe, typically 3.5" or 4" diameter. Common in Ontario post-war construction. Lifespan 50-75 years in dry conditions. In wet basements, base corrosion is the primary failure mode. Signs of failure: visible rust scale or pitting, deflection or lean, concrete pad deterioration.
Wood posts (pre-1950 homes): Susceptible to rot and insect damage. Wood posts in contact with concrete must be replaced with steel or treated lumber with proper isolation membrane.
Adjustable steel teleposts (modern standard): Allow height adjustment during installation. Must be locked (welded or pinned) after installation — adjustable columns are not designed for permanent use.
Steel I-Beam Assessment
Surface rust is normal. Active pitting rust reducing web or flange thickness requires structural engineer assessment. Temporary shoring cost while beam is replaced: $500-$1,500.
Replacement Costs (GTA 2026)
  • Single lally column replacement: $800-$2,500 (including temp support, new column, base/top plates, concrete pad)
  • Full beam and column system (3 columns, 20m beam): $6,000-$15,000
  • Structural engineer assessment: $500-$1,200
  • Municipal permit: $200-$500
Related guides on home.renovation.reviews
Most lally column problems we see in GTA basements show up alongside water issues, so it pays to read these together:
If you have a column or beam concern in your basement, post a photo and a quick description of the symptoms (lean, rust, deflection, water staining) below and we will weigh in.
Full structural guide: https://telegra.ph/Ontario-Lally-Column-and-Steel-Beam-Replacement-Guide-2026---Costs-and-Structural-Requirements-04-26
This is one of those guides that pays for itself the first time someone actually reads it. A couple of additions from the field:
Do not jack a sagging beam fast. We tighten adjustable columns 1/8 turn a day, not a week of slack at once. Drywall, plaster, and ceramic upstairs all need a chance to creep without cracking. Skip that and you are paying a drywaller to chase fresh stress fractures for a month.
Adjustable columns are a temporary product, full stop. Even the heavy-duty ones with the welded base plate are not designed to live in a finished basement forever. If you are refinishing, plan the budget for permanent steel posts welded to a base plate on a properly sized footing - that is what an OBC review wants to see, and it is what your inspector will flag if you sell.
Get the engineer involved before the demo, not after. We see homeowners pull a wall, find a beam that does not look right, and then call. By that point the load path has already shifted and the engineer’s options shrink. A quick site visit before you swing the hammer is always cheaper.
One last red flag for everyone DIYing this: a 2x4 wedged on top of a hydraulic floor jack is not temporary shoring. Cribbing, screw jacks rated for the load, or proper steel posts. Floor jacks are for changing tires.
