Ontario Spray Polyurea and Waterproofing Membrane Guide 2026 - Flat Roofs, Decks and Foundations
Spray polyurea and liquid-applied waterproofing membranes are high-performance systems for Ontario flat roofs, balconies, parking decks, and foundations. This guide covers material types, applications, and 2026 GTA cost ranges.
Material Types
Spray polyurea: Two-component, sets in seconds, 300-400% elongation, excellent crack bridging. Requires heated plural-component spray equipment — specialist application only. Cost: $8-$18/sq ft installed.
Liquid-applied polyurethane membrane: One or two component, 24-72 hour cure. Standard for pedestrian traffic-bearing surfaces (balconies, walkways). Good flexibility and UV resistance. Cost: $6-$14/sq ft.
Elastomeric acrylic/silicone coating: Brush or spray over sound existing substrate. Reflective, UV-resistant, 200-400% elongation. Not standalone waterproofing — substrate must be sound. Cost: $2-$5/sq ft.
Ontario Applications
Flat/low-slope roofs: Polyurea and polyurethane used for new and remedial flat roofing. Seamless systems excel at complex penetrations, drains, curbs.
Parkade decks: High traffic, vehicular loading, de-icing salt exposure. Polyurea with aggregate broadcast is dominant for vehicular-rated surfaces. Cost: $10-$20/sq ft.
Balcony waterproofing (pedestrian): Liquid polyurethane traffic-bearing membrane, two-coat with aggregate broadcast for slip resistance. OBC requires 1:50 minimum slope to drain — verify before application.
Foundation exterior: Spray polyurea over prepared foundation before backfill. Cost: $4-$8/sq ft as part of excavation project.
Related guides on home.renovation.reviews
If you are scoping a waterproofing project this spring, these companion threads cover the adjacent decisions homeowners ask about most often:
Working on a flat roof, balcony, or foundation membrane project this spring? Reply with photos and the substrate type and we will weigh in on which of these systems actually fits your situation.
Full guide: Ontario Spray Polyurea and Elastomeric Coating Guide 2026 - Roofs, Decks and Foundations – Telegraph
Good rundown. The thing I would underline for homeowners is that on every waterproofing failure I have been called back to over the years, it was prep, not the product. Spray polyurea, peel-and-stick, hot-applied rubberized asphalt - they all work when the substrate is right and they all fail when it is not.
A few field notes:
Substrate has to be dry. Polyurea will skin over damp concrete and you will not see the failure for two seasons. We test with a moisture meter before scheduling, and on flat roofs we wait a full 28 days after a fresh pour.
Spec the dry mil thickness, not just the gallon count. On flat roofs we want 60 to 80 mil minimum for polyurea. Anything thinner and you will see hairline tears at flashings within a couple winters.
Cold-weather application is a no-go for most chemistries. Manufacturers list 5C as a floor, but in practice we do not shoot polyurea below 10C unless the deck is heated. If the substrate is colder than the dewpoint, you have wasted the day no matter what the spec sheet says.
Foundations are a different conversation. There, spray polyurea is overkill 90 percent of the time - properly detailed peel-and-stick plus a dimple board does the same job for a fraction of the cost.
