GTA Kitchen Renovation Costs in 2026: What to Expect
Spring is the time when a lot of GTA homeowners sit at their kitchen table, look around, and think: this has to change. Old cabinets, a layout that never made sense, a backsplash from 2003. Kitchen renovations are consistently one of the top requested projects we see here on the forum, and in 50 years of renovations across the Toronto area, kitchens remain one of the most asked-about topics.
So what does a kitchen renovation actually cost in the GTA right now? Here’s an honest breakdown.
The three tiers of kitchen renovation
Budget refresh ($15,000-$35,000): Painting or refacing existing cabinets, new countertops (laminate or entry-level quartz), updated hardware, a new sink and faucet, and basic appliance swaps. You’re keeping the existing footprint and layout. Labour and materials are predictable here. If your bones are good, this range goes a long way.
Mid-range renovation ($40,000-$75,000): New cabinet boxes (typically semi-custom from Canadian suppliers), quartz or stone countertops, tile backsplash, updated plumbing and lighting, and new appliances. This may include removing a non-load-bearing wall to open the space up. This is where most GTA homeowners land.
High-end custom ($80,000+): Custom millwork, premium appliances, stone countertops, smart lighting integration, and structural changes. In a Toronto semi-detached or detached home with an older layout, full kitchen gut-and-rebuilds can hit $120K-$150K depending on scope.
What’s pushing costs higher in 2026
A few things are making kitchen budgets harder to pin down this year.
Tariffs on materials. As we covered in our recent post on tariffs and supply costs, lumber, cabinetry hardware, and some appliance lines are all feeling the impact of cross-border trade pressure. Expect quotes to reflect a 10-15% buffer that wasn’t there in 2024.
Labour. Skilled trades are booked. Qualified kitchen installers, electricians for lighting and appliance circuits, and plumbers are all running 4-8 week lead times right now in the GTA. Rush jobs cost more. Booking early gives you leverage on price.
Design scope creep. What starts as “just new cabinets” often becomes “and we should move the island” and “what about that wall.” Define your scope tightly before getting quotes. Once walls are open, costs multiply.
What you can actually control
First, keep your plumbing and electrical in the same locations if at all possible. Every time a drain moves or a panel gets upgraded, the number climbs fast.
Second, cabinet supplier choice matters a lot. There is a wide range between IKEA-based builds (genuinely solid for budget projects), semi-custom Canadian brands, and full custom millwork. For most mid-range projects, semi-custom gives you the look without the lead time.
Third, sequence your work properly. If your kitchen reno is part of a bigger project, plan it alongside flooring and painting, not after. Doing work in the right order avoids damage and double-billing.
Finally, get multiple quotes. We’ve put together a guide on what to ask your contractor before signing. Three quotes minimum. Ask each contractor to break out labour and materials separately so you can compare apples to apples.
The realistic takeaway
A kitchen renovation in the GTA in 2026 should not be planned around a single ballpark number you found online. Costs vary dramatically based on your specific home, the trades you use, and the scope you’re committing to. The tariff and material environment is adding real uncertainty to pricing this year, so building in a 10-15% contingency is not paranoia, it’s just smart planning.
Start with a clear list of what you need vs. what you want. Get quotes from licensed contractors. And if you’re unsure about scope, book a consultation before you commit to anything on paper.
What’s driving your kitchen renovation in 2026? Budget limit, layout frustration, or just tired of looking at the old one? Drop your situation below and I’ll share what’s worked for homeowners in similar positions.
Related on home.renovation.reviews:
LF Builders has been renovating GTA homes for over 50 years. LF Builders also supports Samm Simon’s 251 km run for cancer research — raising funds one kilometre at a time.
More from LF Builders: Renovation guides and project advice on the LF Builders blog.
One thing worth flagging for anyone using those cost tiers as a planning number: the tier you start in is often not the tier you finish in, and it is rarely because of scope creep on your end.
The most common culprits we see on GTA kitchen projects that push budgets up:
Knob-and-tube or aluminum wiring. Kitchens require dedicated circuits for appliances, and the moment an electrician opens a wall and finds old wiring, the conversation changes fast. In Toronto housing stock built before 1960, this is not a surprise — it is a near-certainty. Budget a $2,000–$5,000 contingency just for electrical if your home is pre-1965.
Plumbing not to current code. If you are moving or adding a sink, Ontario plumbing code has specific trap, vent, and drain requirements. Older homes often have cast iron drains that need partial replacement. Not glamorous, but if it is there, it has to be done.
Mold or water damage behind the old cabinets. Particularly around the sink cabinet and dishwasher area. We see this on probably a third of full kitchen gut jobs in older GTA semis and detached homes. Factor in $1,500–$4,000 for remediation if the bones are older.
The practical takeaway: whatever tier your quote lands in, hold 15–20% back as a genuine contingency — not for upgrades, for surprises. The homeowners who plan for this have a much smoother experience than the ones who spend every dollar on cabinets and have nothing left when the wall opens up.
If you are early in the planning stage, it is worth having a conversation about what a proper pre-renovation inspection looks like before any quotes go out.
Watch: Kitchens renovation shorts
