GTA Kitchen Cabinet Refacing Spring 2026: Veneer Wrap vs Rigid Thermofoil vs Door-Only Replacement, Real Costs by Method, and When Refacing Doesn't Pay
Refacing is the kitchen renovation a lot of GTA homeowners should be doing and aren’t, because the conventional wisdom of “if you’re touching the kitchen, do the whole thing” is bad advice for the homes it’s bad advice for. If your cabinet boxes are sound, your layout works, and your only real complaint is that the doors look like 1998, refacing buys you a kitchen that reads as new for somewhere between 30% and 50% of what a full replacement costs. The catch is that “if your boxes are sound” carries more weight than most quotes acknowledge, and the four common refacing methods are not interchangeable. Picking the wrong one for your cabinet condition is how a $6,000 project turns into a $4,000 lesson and another $14,000 to actually fix it.
This is the spring 2026 buyer’s guide we wish more GTA homeowners had read before they signed.
The four methods, ranked by what you actually get
Painting is the cheapest path and the one with the shortest half-life. A well-prepped, sprayed-on-site paint job runs roughly $1,500 to $3,500 for a 10×10 kitchen. The honest expectation is 5–7 years before the high-touch doors (under the sink, by the stove) start showing wear, and significantly less if your cabinets are thermofoil or laminate to begin with, since paint has bonding problems on those surfaces unless the prep is meticulous, and most quoted jobs aren’t.
Door-only replacement keeps your boxes, replaces the doors and drawer fronts with new ones, and leaves the cabinet face-frame finish alone. Cost typically lands at $2,500 to $5,500 for a standard 10×10. The result is half-and-half: shiny new doors against an aged frame surface. It works when your face frames are still in good shape and you’re not doing a full colour change. It looks bad when the frame finish is more than a few shades off the new doors.
Veneer wrap with new doors is the mid-tier choice and the one a lot of Toronto specialists default to. The shop wraps your existing boxes and face frames in a thin wood veneer or laminate, then installs new doors and drawers that match. For a 10×10 GTA kitchen, this lands at roughly $4,500 to $9,500 depending on door style, hardware, and whether you also swap drawer slides for soft-close. This method gives you a uniform finish across the whole kitchen and lets you change colours, including going to a darker stain, without the seams showing.
Rigid Thermofoil (RTF) doors over MDF is the cleanest, most consistent finish you can get short of full replacement. The doors are MDF cores wrapped in heat-formed thermofoil at the factory, paired with thermofoil-skinned face frames. A GTA kitchen with RTF refacing typically runs $5,500 to $11,000. RTF is harder than paint, more uniform than veneer, and the warranty is usually 5–10 years on the foil bond. It is also the method that tells you nothing about your underlying boxes. That matters if those boxes are particleboard from 1985 with sagging shelves.
For comparison, a full cabinet replacement in the GTA in 2026 runs $14,000 to $32,000 for the same 10×10 footprint, and that’s before counters, backsplash, and any plumbing or electrical changes. The full GTA kitchen reno cost picture is here: GTA Kitchen Renovation Costs in 2026.
When refacing doesn’t pay
Three conditions kill the math. Your boxes have water damage from a sink leak, in which case any refacing method is hiding rot that will surface within two years. Your layout is the actual problem (galley you hate, no island, terrible work triangle), in which case a new finish on the same bad layout is money you’ll regret. Or your boxes are particleboard, your shelves are already sagging, and the hinges are pulling out of soft material. Adhering veneer or thermofoil to a structurally compromised box is finishing a foundation that needs to be replaced.
The rule we apply: open every door, look at every shelf, push every drawer in and out twice. If anything moves more than it should, refacing is not the project you’re doing.
If you are seriously thinking about island work as part of the same renovation, GTA Custom Kitchen Island Spring 2026 covers the sizing math, plumbing reality, and cantilever limits. Adding an island is often the inflection point that pushes a refacing job into a partial replacement.
Hardware, soft-close, and the parts most quotes underspecify
A good refacing quote includes new hinges (concealed, soft-close), new drawer slides (full-extension, soft-close), and new pulls or knobs. A bad refacing quote keeps your old hardware. Old hinges on new doors look fine for a year and then start failing, because the old screw holes were sized for the old hinge cup and the new doors stress them differently. Insist on new hinges. The line item is usually $300–$600 for a standard kitchen and pays for itself the first time you slam a cupboard.
Drawer slide upgrades are the single highest-perceived-value spend in a refacing job. Going from 30-year-old metal slides to soft-close full-extension slides is a tactile upgrade your hands feel every time you cook. Budget another $200–$400 for the slide swap on a typical 8–10 drawer kitchen.
Permit reality (there isn’t one for refacing)
Refacing is cosmetic. There is no Ontario permit required for door swaps, veneer work, or thermofoil application, since none of it is structural, electrical, or plumbing. The only time a permit enters the picture is if you’re moving a cabinet that contains wiring or plumbing, or removing a wall to extend a run. The general permit picture is well-covered here: Toronto renovations that need permits.
Timeline reality
Painting is 3–5 days on-site. Door-only replacement is 1 day after the doors arrive (lead time 2–4 weeks). Veneer refacing is 3–5 days on-site after a 2–3 week shop fabrication window. RTF refacing is 4–7 days on-site after a 3–6 week shop window. Plan the start date 4–8 weeks after you sign, not 4–8 days. Anyone quoting a 1-week turnaround from contract to finished kitchen is either swapping in stock doors that may not match your cabinet sizes, or has a problem coming.
What to ask before you sign
Ask which boxes will be wrapped or skinned, and which will be left as-is. Ask whether the quote includes new hinges and slides or only new doors. Ask for the warranty period in writing on the foil or veneer bond, separate from the labour warranty. Ask for two recent local references and look at the work yourself. And get a written line item for what happens if a box is found unsalvageable mid-job. The answer should be a per-box replacement price, not “we’ll figure it out.”
The bottom line by budget
Under $4,000: paint or door-only on a kitchen that’s already in decent shape and just looks dated. Don’t expect 10 years out of it.
$4,000–$8,000: veneer wrap with new doors and new hardware on a kitchen with sound boxes. This is the GTA refacing sweet spot: uniform finish, real durability, half the cost of replacement.
$8,000–$12,000: RTF refacing or premium veneer with full hardware overhaul, drawer slide upgrade, and possibly a paint-in lighting under-cabinet line. This is the highest spend that still beats replacement on cost-per-year-of-life.
Above $12,000: you are within $3,000–$5,000 of a real cabinet replacement. At that point the math flips. Get a replacement quote before signing the refacing contract.
This topic is part of our spring 2026 GTA kitchen series. Helpful contributions earn $RENO on the community leaderboard. See how the forum works for the tier ladder and Solana wallet setup. If you’ve done a refacing job in the GTA recently (or one that went sideways), drop the actual cost, contractor, and what you’d do differently. Real numbers from real homes are what makes this thread worth reading.
