Financing Your GTA Renovation in 2026: What Actually Works
Spring is the busiest time for renovations in the GTA, and right now I’m getting a consistent question from homeowners that isn’t about tile or lumber — it’s about how to pay for the work.
Costs are up this spring. Skilled trades are running $60-$100/hour, materials have been volatile thanks to tariff pressure on lumber and steel, and even a cosmetic kitchen refresh is averaging $9,000-$12,000 in the GTA. For anything substantial — a full bathroom, a basement, exterior work — you’re looking at $40K to $80K or more.
Most homeowners aren’t writing that cheque out of savings. So here’s an honest rundown of the financing options we see most often after 50 years in the trades — and what actually makes sense.
HELOC (Home Equity Line of Credit)
This is the most common tool we see. You borrow against your home’s equity, draw on it like a revolving credit line, and pay interest only on what you’ve pulled. Rates are typically variable — prime plus 0.5% to 1% in Canada.
Good for: phased renovations where you’re not locked into a final cost upfront. Kitchen this month, bathroom in the fall.
Watch for: variable rate risk. If prime moves up while your project is mid-stream, your carrying cost goes up too. If you’re already stretched, a fixed product gives more predictability.
Home Equity Loan (Second Mortgage)
Fixed amount, fixed rate, fixed monthly payments. Good for a defined scope — “we’re doing the basement and we know it’s going to be $55,000.”
The rate is usually slightly higher than a HELOC, but the predictability is valuable when you’re budgeting around a contractor’s timeline and milestone payments.
Unsecured Line of Credit
Available without home equity, but limits are lower and rates are higher — 8-12% vs. 4-6% for secured products. We see this used for smaller cosmetic work: paint, flooring, fixtures. For a $20,000 bathroom reno, the interest adds up fast.
Rolling Into a Mortgage Renewal
If your mortgage is coming up for renewal anyway, folding reno costs in can make sense. The problem is timing — if you’re not at renewal, breaking your mortgage early usually costs more than it saves in 2026.
A Few Things I’d Tell Any Homeowner
After 50 years of building in the GTA, a few things we’ve seen go sideways on the financing side:
Get financing confirmed before booking a contractor. Projects that stall mid-build because the money wasn’t in place cost everyone — materials sit exposed, subcontractors reschedule, and you’re paying holding costs on a half-done kitchen.
Build in 15-20% contingency. This isn’t padding. Hidden rot behind a wall, asbestos tile under old flooring, an electrical panel that needs upgrading — we find this stuff on a regular basis. The homeowners who budgeted for it come out fine. The ones who didn’t have hard conversations.
Watch payment structures. A contractor asking for 50% upfront before breaking ground is a red flag. Structure payments to milestone completion: demo done, rough-in done, finishes done, final walkthrough.
There’s an older thread here worth reading if you’re weighing options: Home improvement vs HELOC?. And if you want a sense of what your project might actually cost before you talk to a lender, the Complete 2026 Renovation Cost Guide for Toronto & GTA Homeowners is a solid reference.
What financing approach have you used for GTA renos? HELOC, savings, something else? Drop it below — genuinely curious what’s working for people in this market.
Related on home.renovation.reviews:
LF Builders has been renovating GTA homes for over 50 years. LF Builders also supports Samm Simon’s 251 km run for cancer research — raising funds one kilometre at a time.
More from LF Builders: Renovation guides and project advice on the LF Builders blog.
