Complete 2026 Renovation Cost Guide for Toronto & GTA Homeowners
2026 Renovation Cost Guide: Toronto & Greater Toronto Area
This thread compiles realistic cost ranges for every major renovation project in the GTA, based on actual homeowner project reports from this community.
Kitchen Renovation
Tier Scope Cost Range
Budget refresh Cabinet reface, counters, paint $15,000 – $30,000
Mid-range Full replacement, semi-custom $40,000 – $70,000
Premium Custom cabinets, layout change $80,000 – $150,000+
Bathroom Renovation
Tier Cost Range
Basic (fixtures, accessories) $5,000 – $10,000
Mid-range (full tile, vanity) $15,000 – $30,000
Full gut (layout change) $35,000 – $65,000+
Basement Waterproofing
Type Cost Range
Interior system + sump pump $8,000 – $20,000
Partial exterior (1 wall) $12,000 – $25,000
Full exterior perimeter $35,000 – $65,000
Interlock Driveway
Scope Cost Range
1-car driveway $8,000 – $15,000
2-car driveway $14,000 – $28,000
Patio (200 sq ft) $6,000 – $14,000
Roofing
Material Cost Range (1,500 sq ft home)
Architectural shingles $8,000 – $18,000
Metal roofing $15,000 – $35,000
Flat roof (torch-on/TPO) $8,000 – $20,000
Deck
Material Cost per sq ft (installed)
Pressure-treated wood $25 – $45
Composite (Trex, TimberTech) $50 – $85
Hardwood (Ipe) $70 – $120
Basement Finishing
Scope Cost Range
Recreational space only $20,000 – $40,000
Full legal suite $50,000 – $100,000+
With underpinning Add $35,000 – $80,000
Key Rule: Budget 15-20% Contingency
Every experienced GTA contractor and homeowner agrees: budget your quoted price plus a 15-20% contingency. In pre-1970 Toronto homes, use 25%. Hidden conditions (asbestos, knob-and-tube, cast iron drains) appear in the majority of older home renovations.
All ranges reflect 2026 Toronto-area market data. Costs vary by neighbourhood, scope complexity, and contractor.
Please add your own project cost reports below to keep this guide updated!
Frequently Asked Questions: GTA Renovation Costs 2026
Q: What contingency budget should I plan for a GTA renovation?
Every experienced GTA contractor agrees: budget your quoted price plus 15 to 20 percent contingency. In pre-1970 Toronto homes, use 25 percent. Hidden conditions — asbestos insulation or floor tiles, knob-and-tube wiring, cast iron drains needing replacement, subfloor rot at tub edges — appear in the majority of older home renovations. This is the consistent finding from 50+ years and 30,000+ projects across Southern Ontario.
Q: What are the most common hidden costs in Toronto renovations?
In pre-1985 homes: subfloor damage at the tub edge or around the toilet flange; aluminum or knob-and-tube wiring requiring ESA remediation before permit closes; undersized drains or venting that do not meet current Ontario Building Code; and asbestos in floor tiles, pipe insulation, or drywall compound. Any project that opens walls or floors in a pre-1980 Toronto home should carry at least a 15 percent contingency for discoveries.
Q: When is the best time to book a GTA contractor for spring 2026?
Now, if you have a defined scope. Quality contractors in the GTA are booking 4 to 8 weeks out through the spring season. Framing lumber is up roughly 5 percent year over year in 2026, and tariff uncertainty on some imported materials is unresolved. Getting a fixed-price quote from a reputable trade early in the season protects against further cost movement and schedule compression.
Q: How much does a full legal basement suite conversion cost in Toronto?
A straightforward legal conversion — egress windows, fire separation, dedicated electrical, permits — typically runs $40,000 to $65,000. Full build with separate entrance and complete kitchen/bath fit-out: $65,000 to $110,000. Where underpinning is needed to achieve minimum ceiling height: $110,000 to $200,000 or more. Always include permit fees, which run $1,500 to $4,000 for this scope in Toronto.
More from LF Builders and home.renovation.reviews
