Ontario Condo Renovation Guide 2026 - Board Approval, OBC Permits and Flooring Rules
Condo renovations in Ontario involve both municipal building permits AND condo board approval. The Condominium Act, 1998 and your building’s Declaration and Rules govern what unit owners can modify. This guide covers the GTA condo renovation process.
What Requires Board Approval
The Condominium Act requires board approval for alterations to: common elements (any part outside the unit boundary), structural changes, and changes to mechanical systems affecting other units. Most condo declarations also require approval for changes affecting noise (flooring), water systems (plumbing modifications), or the building envelope.
Check your Declaration first — it defines where your unit ends and common elements begin.
Flooring Changes
Replacing carpet with hard flooring (hardwood, LVP, tile) is the most common GTA condo renovation. Nearly all condo boards require approval and specify minimum Sound Transmission Class (STC) and Impact Insulation Class (IIC) ratings — typically IIC 50+ minimum, many GTA buildings require IIC 55-60. Underlayment selection is critical — not all LVP underlayments meet condo IIC requirements.
Standard Board Application Process
Submit written application to property manager: describe scope, materials, contractor details, start/end dates. Include contractor WSIB and insurance certificates. Board review: 30-60 days typical.
Municipal Permits Still Required
Board approval does NOT replace municipal building permits. If your renovation requires a building permit (structural changes, HVAC, electrical, plumbing), you still need municipal application. ESA permits for electrical work are required regardless of board approval.
Related guides on home.renovation.reviews
Renovating a condo in the GTA right now? Drop your building (no unit numbers), your scope, and the IIC rating your board is asking for - the community has war stories on which underlayments and contractors actually pass the post-install sound test, and which boards are tightest on hours and elevator booking.
Worth layering in some market context here, because it changes how condo owners should be thinking about the scope and timeline of their renovation.
BNN Bloomberg reported last month that GTA condo owners are shifting to renovations at a meaningful rate — a survey found roughly 34% of respondents said they’re more likely to spend money on a renovation in 2026 than last year. The reason is straightforward: units aren’t moving the way they were, so owners who planned to sell are now asking “what can I do to make this space work for the next 10 years?” That mindset shifts the calculus on budget and spec. If you’re renovating to sell in six months, you want the cheapest compliant option. If you’re staying, it’s worth getting the flooring assembly, plumbing rough-in, and finishes right the first time.
A few things I’d add from our experience doing GTA condo work:
Flooring underlayment — confirm the current standard in writing. Many buildings say “IIC 50 minimum” in their Declaration but have effectively enforced IIC 55-60 for years, especially in older concrete buildings where impact noise travels badly. We’ve seen owners purchase LVP underlayment that technically meets the Declaration’s IIC 50 floor, only to have the property manager reject it because a subsequent board resolution quietly raised the building standard. Always get the current requirement confirmed in writing from the property manager before purchasing materials.
Board timelines can stretch beyond the 30-60 day range. If your building has an active AGM season or a property management company transition happening, applications can stall. Build contractor scheduling buffer accordingly — especially if you’re planning a spring start.
Toronto permit fees went up 4.82% on January 1, 2026, and the City updated its application form on February 16, 2026. If your project was scoped or quoted last fall, re-run the fee calculation and confirm you’re using the current form before submitting — the old form is rejected outright.
Anything specific you’re working through on a condo reno? Happy to troubleshoot.
