Toronto Renovation and the Ontario Building Code: What Homeowners Need to Understand
The Ontario Building Code (OBC) governs virtually every renovation that requires a permit in Ontario. Most homeowners have never read it — here’s what matters for typical residential renovations.
What the OBC Controls
The OBC sets minimum standards for structural integrity, fire safety, energy efficiency, plumbing, electrical (via Ontario Electrical Safety Code), and accessibility. When a building inspector approves your work, they’re confirming compliance with these standards.
Key OBC Requirements for Common Renovations
Basement suites:
  • Minimum ceiling height: 1.95m (6’5") in habitable rooms
  • Bedroom egress window: 0.35m² opening, sill max 1m above floor
  • Fire separation: 30-minute fire-rated assembly between suite and remainder of house
  • Smoke and CO alarms: interconnected, in every bedroom and outside sleeping areas
Additions:
  • Must match or exceed the energy efficiency of the existing building envelope
  • Foundations must reach below frost line (1.2m in Toronto area)
  • Structural elements must meet span tables in OBC Division B
Electrical:
  • Ontario Electrical Safety Code (separate from OBC but administered similarly)
  • All new electrical work requires ESA inspection
  • AFCI breakers now required for bedroom circuits in many renovation scenarios
The Inspector Is Your Friend
Building inspectors in Toronto are not trying to stop your project. They’re ensuring the work is safe. Calling them to ask a question before building is always smarter than asking for forgiveness after.
Discussion at home.renovation.reviews — there are several threads specifically on OBC requirements for basement suites and additions.
