Flooring Options for Toronto Homes 2026: Hardwood vs LVP vs Tile
After seeing the same flooring questions repeatedly, here’s a comprehensive breakdown for Toronto homeowners in 2026.
Cost Comparison (Supply + Install, per sq ft)
Flooring Type Low High Best For
Solid hardwood $10 $20 Main living areas
Engineered hardwood $8 $16 Basement-adjacent
Luxury Vinyl Plank $5 $10 Wet areas, rentals
Porcelain tile $8 $18 Kitchen, bath
Carpet $4 $8 Bedrooms
Key Toronto Considerations
Basements: Never install solid hardwood below grade. LVP or engineered are the right call.
Radiant heat: Engineered and some LVP work. Tile is the best conductor. Solid hardwood performs poorly over in-slab heat.
Heritage homes: Original fir floors can often be refinished 2–3 more times if they’re thick enough.
Questions to Ask Your Flooring Contractor
  1. What acclimation period do you allow before installation?
  2. What moisture reading is your cutoff for concrete slab installs?
  3. Do you include 10% overage in the quote?
Drop your own experiences below — what worked, what didn’t, who you hired.
