GTA Condo Renovation 2026: Board Approval, Rules, and What Unit Owners Can Actually Do
Renovating Your GTA Condo in 2026: The Practical Rulebook
Condo renovation in Ontario operates under both the Condominium Act and your specific corporation’s Declaration, By-Laws, and Rules. Here’s what owners actually encounter.
What You Own (And What You Don’t)
You typically own the interior of your unit — drywall finishes inward. The structure (concrete slab, exterior walls, shared plumbing stacks, common HVAC) belongs to the corporation. This creates real constraints.
Common GTA Condo Board Rules (2026)
  • No removal/alteration of load-bearing elements without structural engineer sign-off
  • Hard flooring (hardwood, tile) only with board-approved acoustic underlay (IIC 60+ typically required)
  • All contractors must provide proof of $2M liability insurance to property management before starting
  • Work hours: typically 8am–5pm Monday–Friday only
  • Elevator booking required for material deliveries (often $250–$500 deposit)
  • No cuts into concrete slab (plumbing reroutes almost never approved in tower buildings)
The Approval Process
Most buildings require a written renovation application to the property manager/board including:
  • Scope of work description
  • Drawings or sketches
  • Contractor name, insurance certificate, WSIB clearance
  • Timeline
Approval typically takes 1–6 weeks. Do not start without written approval. Violations can result in forced restoration at your cost.
What’s Usually OK Without Board Approval
  • Painting walls and ceilings
  • Cabinet replacement (no plumbing moves)
  • Appliance swaps
  • Light fixture swaps at existing locations
  • Flooring replacement with compliant underlay
Tips From Experience
  1. Get your property manager’s contact before planning — they’ll tell you building-specific rules faster than reading the declaration
  2. Book the elevator 2+ weeks in advance for any project requiring material delivery
  3. Give neighbours notice — the relationship matters in a shared-wall building
LF Builders has completed GTA condo renovations across dozens of buildings: lfbuilders.ca
Condo reno experiences: home.renovation.reviews
Samm Simon 251 KM for cancer: sammsimon.ca
