Ontario 200A Electrical Panel Upgrade: Process, Utility Coordination & 2026 Costs
Most Ontario homes built before 1990 have 100A service. Modern homes with EV chargers, heat pumps, and high-draw appliances routinely need 200A. Here is the full process for 2026.
The Upgrade Process
  1. Licensed electrician submits ESA permit
  2. Homeowner contacts hydro utility (Toronto Hydro, Hydro One, Alectra) for service upgrade scheduling
  3. Service entrance and meter base replaced
  4. New 200A panel installed inside home
  5. ESA inspection and certificate issued
  6. Utility reconnects service
Utility Coordination: Plan for It
Utilities take 4-12 weeks for service upgrade appointments. This is the most common source of project delays. Contact your utility early — before booking dependent work like heat pump or EV charger installation.
Costs in Ontario 2026
200A panel upgrade: $3,500-$7,000 including ESA permit. Service entrance cable replacement if needed: +$1,500-$4,000. Sub-panel addition: +$1,000-$2,500. Knob-and-tube or aluminum wiring remediation: quoted separately.
Rebates
Canada Greener Homes Grant may include panel upgrades as part of heat pump or electrification projects. Check current program eligibility before starting.
Share panel upgrade experiences and find Ontario electricians at home.renovation.reviews.
