GTA Standby Generator Install 2026: Brands, Permits, Costs
Most GTA homeowners only think about a standby generator after the second multi-day outage. By that point the August storm queue has already filled up at every reputable installer, and the lead time on a 22 kW Generac with an automatic transfer switch is measured in months rather than weeks. Spring is the better window for two reasons: the gas-line and panel-upgrade trades have capacity, and the Electrical Safety Authority and Technical Standards and Safety Authority paperwork can both finish before the summer storm season opens.
This guide walks through the four decisions that drive the price, the permit work that catches first-time buyers off guard, and the real installed-cost bands we have been seeing across Toronto, Mississauga, Brampton, Vaughan, and Markham this spring.
Why spring is the right window to install
Standby generators are not a “buy it on the way home from Home Depot” appliance. A typical install needs a sized natural-gas line from the meter (or a propane tank with a calculated regulator drop), a concrete or composite pad, an automatic transfer switch wired into the service panel, an ESA permit and inspection, a TSSA fuel-side acceptance for the gas connection, and Enbridge sign-off on the meter capacity. Most installs run two to four weeks from contract to commissioning, but the long pole is almost always the gas-side coordination.
In late spring the schedule slack lines up. ESA inspectors are not yet booked solid on summer panel-upgrade calls. Enbridge meter visits are running on four to six week windows instead of the eight to ten of high summer. And the homeowner gets the unit pressure-tested, ATS commissioned, and a clean cold-start cycle on the books before the first July thunderstorm puts the system to actual work.
A real install also requires a sustained pad-pour weather window: dry ground, temperatures above five degrees, and enough setback from the gas meter, the property line, and any window or fresh-air intake. Late May through late June is the easiest combination of all three.
How to size: stand-alone load math vs whole-home
Sizing is where most quotes go off the rails. There are two valid approaches and they produce very different numbers.
The first is critical-loads sizing. You pick a small list of items the house cannot lose during an outage: furnace blower, sump and ejector pumps, fridge, one or two key circuits for lights and outlets, the freezer, modem and router, a single 240-volt circuit for a window AC or a heat-pump head. That total typically lands between 8 and 14 kW running load with a 50 to 70 percent surge buffer, which puts you in the 11 to 14 kW air-cooled standby class.
The second is whole-home sizing. You assume any breaker may close at any moment, including the central AC, the dryer, the range, and an EV charger if there is one. With a typical Toronto detached home of 2,000 to 2,800 square feet running a 4-ton AC, a 240V dryer, a 40A range, and a 32A EV charger, real running load with sensible load-shed averages 18 to 22 kW continuous, which lands you in the 22 to 26 kW class. Without a load-shed module on the AC and dryer you climb to 24 to 30 kW.
The second approach is the higher-revenue answer for an installer. The first is usually the right answer for a Toronto homeowner. A 14 kW unit with a critical-loads subpanel does the work of preserving comfort, food, and basement dryness for a fraction of the cost of a 26 kW system that keeps the central AC running while the rest of the street is dark. If you are sizing for medical equipment, a home office that must stay live during business hours, or a finished basement with a permanent home theatre and dehumidifier, climb the ladder accordingly.
A licensed electrician should run the calculation against the National Electrical Code residential demand factors before the brand is even on the table.
The brand decision: Generac, Kohler, Briggs & Stratton
Most GTA installs come down to three nameplates.
Generac dominates the air-cooled residential category because of distribution, parts availability, and the Mobile Link cellular monitoring that ships standard on the 22 and 26 kW models. The 22 kW Guardian is the highest-volume unit in southern Ontario right now, and a Generac dealer can usually have a unit on a pad inside three weeks if the gas and panel work are already done. Warranty is 10 years on the 22 kW Guardian and longer on commercial-grade lines, which is unusual at this price point.
Kohler tends to win on the engine side. The KCG series uses a heavier engine block, runs quieter at the property line, and holds voltage and frequency regulation tighter under shock loads. That matters if the standby is going to be living next to a sensitive HVAC variable-speed air handler or a server stack. Kohler’s standard residential warranty is five years, with extended terms available. Distribution in southern Ontario is thinner, and parts can be a one-week ferry from a regional warehouse.
Briggs & Stratton sits in the budget-friendly tier. The Fortress and PowerProtect units cover the same kW range, but the engineering is one notch back, the noise output is a few decibels higher, and the smart-home integration is less polished. The seven-year warranty is competitive on paper, and on a 14 kW critical-loads install for a budget-conscious buyer, the brand makes sense.
What does not matter, for a typical Toronto homeowner, is the difference between a 22 kW Generac and a 26 kW Kohler at idle. Both will start, both will hold, both will outlast the average mortgage. The brand decision is mostly a noise-and-warranty exercise, and the sizing decision is a much bigger lever on cost.
Transfer switch choices: manual, automatic, whole-home, critical-loads
The transfer switch is the part of the install that turns a generator into a code-compliant standby system. Direct connection through a dryer outlet or a backfeed plug is illegal under Ontario Regulation 22/04 and dangerous to the linemen working on the grid during an outage.
There are four real options.
A manual transfer switch is the budget tier. The homeowner walks into the basement during an outage, throws a knife switch from utility to generator, and the unit takes the chosen load. Cost is roughly $400 to $700 for the switch plus $600 to $900 in install labour. It works fine for a portable generator. It does not work for a true standby.
A whole-home automatic transfer switch sits between the meter and the service panel and switches the entire panel from utility to generator within ten seconds of an outage. The unit is rated to the full service amperage, usually 200 amps, and runs about $1,400 to $1,900 in materials with $800 to $1,200 in labour. It is the right answer for a 22 to 26 kW system and is what Generac ships as standard with the Guardian package.
A critical-loads ATS is the size-conscious answer. The homeowner picks a subpanel of essential circuits and the ATS only switches that subpanel during an outage. The main panel stays on utility and stays dark when the grid is down. Materials run $900 to $1,400, labour $700 to $1,000. Pairs naturally with a 14 kW unit and a 60 to 100 amp critical-loads subpanel.
A service-entrance rated ATS is the same as the whole-home but combines the main service disconnect into the same enclosure. Saves a wall section in a tight basement and shaves $200 to $400 in labour. Generac and Kohler both make these for their Guardian and KCG lines.
The gas line side: TSSA, regulator, line sizing
A 22 kW natural-gas standby will pull around 380,000 BTU at full load. That number has to fit inside the existing meter capacity at the curb plus everything else the house already runs: furnace, water heater, range, fireplace, dryer if gas, BBQ stub if installed. On older Toronto detached homes with a 250-cubic-foot-per-hour residential meter the answer is often that the meter has to be upsized to a 425 or 630 CFH class before the generator can be commissioned. Enbridge does the meter swap, but the homeowner schedules and pays for it through their installer.
The line from the meter to the generator pad has to be sized for the run length. Five-eighths-inch corrugated stainless tubing handles a short run of less than 30 feet to a 22 kW unit. Longer runs of 40 to 80 feet step up to three-quarter or one-inch black iron. The installer sizes the run against the NFPA 54 / CSA B149.1 tables. Doing this wrong starves the engine during a cold start and shows up as a hard fault on the unit’s display, often months after the install when the homeowner finally has a real outage to test it on.
TSSA is the second permit. Any new gas line connection or appliance approval for the GTA passes through a registered gas fitter, who pulls the TSSA paperwork, completes the install, and calls in the inspector. On a straightforward install the TSSA permit and inspection adds $200 to $400 in fees and three to five business days to the schedule.
The electrical side: ESA permit and inspection
The Electrical Safety Authority side runs in parallel with the gas side. A licensed electrical contractor pulls the permit, wires the ATS, runs the generator’s control conduit back to the panel, and calls for inspection. The fee schedule is typically $250 to $450 for a residential standby system. ESA inspectors look for proper bonding of the generator chassis, correct breaker coordination at the ATS, mechanical interlock between the utility and generator sides of the switch, and a correctly sized neutral conductor.
A common gotcha: if the existing service is a 100-amp panel and the generator is a 22 kW class, the inspector usually requires a service upgrade to 200 amps before sign-off, because the ATS rating has to match or exceed the service rating. We covered the 200-amp upgrade math at length in Ontario 200A Electrical Panel Upgrade: Process, Utility Coordination & 2026 Costs. Read that piece before you sign a generator contract if your panel is still on a 100-amp service.
A second gotcha: for homes with solar PV plus a battery, the ATS has to coordinate with the inverter’s anti-islanding logic, and a critical-loads ATS is usually the cleaner answer than a whole-home ATS. The case study at Installed a 20kW Generac standby generator in Uxbridge: full permit process and winter performance walks through the rural variant of this same coordination problem.
Real GTA cost bands spring 2026
These are installed-and-commissioned costs, not unit-only.
A 14 kW air-cooled unit on a critical-loads ATS with a short gas run, an existing 200-amp service, and no panel upgrade lands at $9,500 to $12,500 in the GTA this spring.
A 22 kW air-cooled unit on a whole-home ATS with a 30 to 50 foot gas run, a 200-amp service already in place, and a meter upsize from Enbridge lands at $13,500 to $17,500.
A 26 kW air-cooled unit on a whole-home ATS, a longer gas run, an existing 200-amp service, and a meter upsize lands at $16,500 to $21,500.
Add $2,000 to $3,500 if a 100-to-200-amp service upgrade is required.
Add $400 to $1,200 for a composite or stamped-concrete pad if the contractor’s standard fibreglass pad does not satisfy a particular setback or aesthetic constraint.
Add $300 to $700 for a Mobile Link or KohlerNet cellular subscription kit if it does not come bundled.
The unit-only line items are $5,800 to $7,800 for a 22 kW Generac Guardian, $7,400 to $9,200 for a 22 kW Kohler 22RCA, $4,800 to $6,400 for a 14 kW Guardian, and $5,200 to $6,800 for a 14 kW Briggs & Stratton Fortress, all in 2026 GTA prices.
Maintenance and operating cost
A standby generator is not a fire-and-forget appliance. Annual maintenance covers oil, filter, spark plugs, valve clearance check, exercise log review, and a load-bank test on units past five years. Most dealers price this at $300 to $500 per visit, and the manufacturer warranty depends on the maintenance log being kept.
Fuel cost during an outage is modest at residential load. A 22 kW unit at half load burns roughly 2.5 cubic meters of natural gas per hour, which is about $1.20 per hour at current Enbridge rates. A 48-hour outage costs $50 to $60 in gas. Propane is more expensive per BTU and storage capacity caps your runtime, but it is the right answer for rural properties without a gas main.
The weekly self-test runs about ten minutes at no load and consumes negligible fuel. It is also the most common reason a unit catches a problem before the homeowner needs the unit to actually work.
Five questions to ask before signing
Before signing any generator contract, get clear answers on the following.
What is the proposed sizing logic, in writing, with the calculation showing peak running load, surge load, and any load-shed strategy?
Is the existing service panel rated for the ATS being proposed, and if not, what is the panel-upgrade scope and cost as a separate line item?
Is the existing gas meter rated for the generator’s BTU draw plus all other gas appliances at peak demand, and if a meter upsize is required, who is scheduling and paying for the Enbridge visit?
Are ESA and TSSA permits included in the quote with their inspection fees, or are they listed as a homeowner-paid pass-through?
What does the maintenance contract look like for years one through five, and is the manufacturer warranty conditional on that contract being maintained with this dealer?
If any of those answers come back fuzzy, get a second quote.
Bottom line by use case
For a homeowner who only needs the basement dry, the fridge cold, and the furnace running through a 12 to 24 hour summer outage, a 14 kW air-cooled unit with a critical-loads ATS and a 60-amp emergency subpanel is the right answer at $9,500 to $12,500.
For a homeowner who wants the whole house live during outages including the central AC, an EV charger, and any 240-volt cooking appliance, a 22 kW air-cooled unit with a whole-home ATS, a 200-amp service confirmed in place, and a meter upsize at $13,500 to $17,500 is the standard fit.
For a home office or medical-equipment household where downtime is not negotiable, a 22 to 26 kW unit with an automatic transfer switch and a maintenance contract that includes a remote monitoring subscription and an annual load-bank test is worth the $16,500 to $21,500 plus the recurring service fee.
For a rural property without a gas main, propane changes the math: tank sizing has to support 24 to 72 hours of expected runtime, and the unit-side cost is roughly $1,500 higher because of the regulator and tank-side gear.
What spring 2026 actually changes is access to the gas-and-electrical trade slack window before summer storm season hits, and the Enbridge meter-upsize lead time being two to three weeks shorter than it will be by July.
home.renovation.reviews has been collecting GTA homeowner reports on standby generator installs for two years. The thread for sharing your install story (with cost, sizing logic, and what surprised you) is open under Ontario, and helpful contributions earn $RENO on the community leaderboard. The public payment ledger at /t/reno-payment-ledger shows what tier-up rewards have been issued. New accounts that link a Solana wallet at signup unlock the airdrop and tier-up rewards. We have been doing GTA renovation, electrical, and home-systems work for more than fifty years, and the breakdowns above reflect what current spring 2026 quotes are landing at across our network.
Companion spring 2026 reading
Ontario 200A Electrical Panel Upgrade: Process, Utility Coordination & 2026 Costs. Required prerequisite reading if your panel is still on a 100-amp service and you are considering a 22 kW or larger generator.
Installed a 20kW Generac standby generator in Uxbridge: full permit process and winter performance. Real homeowner case study with full cost line items and the ATS coordination they had to redo when their solar inverter went in two years later.
GTA BBQ and Outdoor Gas Line Install Spring 2026: TSSA Permits, Real Costs, Black Iron vs CSST. Sister piece on the TSSA gas-line permit side, useful for understanding what your gas fitter is actually filing on the generator install.
GTA Sump Pump Battery Backup Spring 2026: Why It’s the One $300 Retrofit Most Toronto Homeowners Should Run First. If your reason for considering a standby is “the basement floods during outages,” the battery-backup retrofit is a fraction of the cost and may be the right first step before a generator quote.
