GTA Asphalt Driveway Install 2026: Hot vs Cold Mix, Costs
Spring is the wrong season to be googling driveway costs. By the time the first frost is gone, every paving crew in the GTA is already booked into June. We get the same call every May: “the asphalt company can be here Friday, is $4,200 a fair price for our driveway?” Sometimes yes. Sometimes the quote is missing the part of the job that decides whether the surface lasts ten years or three.
This is the buyer-side guide we use with our own LF customers when they are deciding between asphalt, concrete, and interlock for a tear-out-and-replace this season. It covers the install itself, not the sealing-only refresh (we already wrote that one over at our GTA driveway sealing spring 2026 thread).
Why the timing matters in spring 2026
Asphalt has a temperature window. The mix needs to be poured hot (around 280-300°F at the truck, 220-240°F at the lay-down), and it needs to cool slowly enough to compact properly before it sets. In practice that means:
  • Ambient air ≥ 50°F (10°C) AND rising through the day
  • Ground temperature ≥ 50°F (the gravel base needs to not pull heat out of the bottom of the asphalt)
  • Dry forecast for at least 24 hours after pour
  • No ponding water on the base
In southern Ontario, that window is usually mid-April through early November in a normal year, with peak-quality conditions in May, June, September, and October. July and August work too, but on a 32°C asphalt-roof afternoon the surface stays soft for longer, and dragging a heavy bin across a fresh driveway in week one will print tire tracks that never come out.
The commercial reality of May is that crews are catching up on the late-March and April backlog. Quotes go up. Booking lead times stretch from one week to four. The flyer-truck pitch (“our crew is in your area Friday, $1.50 a square foot, today only”) usually shows up exactly when proper crews are unavailable. We have a separate post on how to read those flyer pitches if you have not seen one yet.
Hot mix vs cold mix: what your contractor should be using
There are two materials that look the same on a delivery slip and behave nothing alike.
Hot Mix Asphalt (HMA) is what should be on a new full-depth driveway. It arrives in a heated dump truck around 280-300°F, gets spread by a paver or by hand, then is rolled with a compactor while still hot. As it cools through the next 24-72 hours it bonds into a continuous slab. A properly installed hot mix driveway in the GTA realistically lasts 15-20 years before it needs to be replaced (longer with a seal coat every 3-4 years after the first cure).
Cold Mix (cold patch) is bagged or pre-mixed asphalt designed to be used at ambient temperature. It is a repair material. It is for filling a pothole in November when no hot mix plant is open, or for patching a single 6-inch crack in your existing driveway. It lasts 6-18 months as a patch, and sometimes less. It is not a full driveway material.
If a quote is suspiciously low and the truck arriving has 5-gallon buckets instead of a heated dump body, that is cold patch being sold as a full install. The surface will dust off, ravel at the edges, and start showing aggregate inside 18 months. Walk away.
The other variant worth knowing is “warm mix asphalt” (WMA), which is hot mix with additives that lower the placement temperature by 50-100°F. It is mostly a commercial-paving and government-paving thing right now in Ontario. A residential driveway should be HMA.
The base prep nobody photographs
Base preparation is 30-40% of the total cost on a proper install, and it is also the part the homeowner cannot see once the asphalt is rolled. It is also the part where corners get cut.
Here is what a full tear-out and replace looks like on a typical GTA semi-detached or detached lot:
  1. Saw-cut and remove the existing surface (asphalt, gravel, or whatever was there). Disposal is usually charged separately, especially if it was concrete.
  2. Dig the sub-base to 12-15 inches below finished grade. Some installers call this “stripping the topsoil and weak material.” On clay soils across most of the GTA, this exposes the native clay or silty-clay subgrade. On the few sand-based pockets (parts of York Region, parts of Whitby) it exposes a sandier subgrade that drains better.
  3. Compact the subgrade with a plate compactor or vibratory roller. This is the gate that prevents the slab from settling unevenly.
  4. Place 6-8 inches of compacted aggregate base. In Ontario this is usually Granular A (a 3/4-inch crushed limestone or recycled concrete blend with fines). Some specs use Granular B (3-inch minus) underneath Granular A on weak subgrades, which adds 2-4 inches to the dig depth.
  5. Compact again, in lifts of 3-4 inches. Skipping a lift means the lower aggregate stays loose and the slab will dish.
  6. Place 3 inches of hot mix in one or two lifts (see next section), rolled to grade.
When a quote comes in 30-40% under the others, the part that is missing is usually here: dig depth at 4-6 inches instead of 12-15, no Granular A under the asphalt, or skipping the lift compaction step. The driveway looks identical for the first season. By spring of year two it has potholes at the joint where the snowplow turns around, and the first 8 feet of driveway by the curb has settled down a half-inch.
This is also the part of the job where access matters. If your driveway is between two close-set houses and the only way in is a 9-foot-wide gap, the contractor cannot bring the standard equipment. They need a walk-behind plate or a smaller skid steer. That adds labour cost and can shift the quote up 15-25% on a narrow city lot. Get a site visit before signing rather than relying on a measurement-by-Google-Earth quote.
Single lift vs two lifts (and what that 3-inch number actually means)
Most GTA residential driveways get 3 inches of finished hot mix. The question is whether it goes down in one 3-inch lift or two 1.5-inch lifts.
Single 3-inch lift is faster and cheaper. The crew shows up, pours, rolls, and is gone the same day. It works fine when the base is well-prepared and the aggregate underneath is correctly graded, because the single lift compacts to a uniform density.
Two-lift install (1.5-inch base course of HL-3 or similar coarse-graded mix, then 1.5-inch surface course of HL-3A or finer-graded mix) is what good contractors recommend for high-traffic driveways or long lanes. The base course has bigger aggregate (better structural strength), the surface course has smaller aggregate (smoother finish, easier to seal in year two). Two lifts costs 10-15% more on a residential job because of the extra mobilization and rolling time, but it adds 3-5 years to the realistic lifespan and the seam between the two lifts handles freeze-thaw better.
If a quote says “3 inches of asphalt” and does not specify single or two-lift, ask. The answer tells you something about the contractor’s training. The Ontario Asphalt Pavement Council’s “ABCs of Driveways” pamphlet is what we point homeowners to if they want the trade-association language.
Real GTA cost bands for spring 2026
Cross-validated against current Toronto-area paving quotes and the Ontario provincial cost data we are seeing in 2026:
  • $3.75-$4.50 per square foot: budget tier. Usually a single-lift install with a thinner base course (4-6 inches of aggregate) on flat, easy-access lots. Often the flyer-truck pitch when they are actually qualified. Lifespan 8-12 years if base prep was actually done.
  • $5.00-$6.50 per square foot: standard mid-tier. Single 3-inch lift hot mix, 6-8 inches Granular A base, full compaction in lifts. This is where most reputable GTA paving companies land for a typical 500-700 sqft driveway. Lifespan 15-20 years with a seal coat every 3-4 years after the first cure.
  • $7.00-$9.00 per square foot: two-lift premium. HL-3 base course plus HL-3A surface course, 8 inches Granular A base, sometimes Granular B under that. This is what we spec for long lanes, sloped driveways, or lots with poor subgrade. Lifespan 20-25 years.
  • $10+ per square foot: usually means difficult access (tight side yard, steep slope, retaining wall integration), heated driveway add-on, or stamped-asphalt finish.
For a typical 500-600 sqft GTA driveway (single-bay) the spring 2026 envelope is $2,000-$5,500 depending on tier. For a 700-900 sqft double-bay it is $3,500-$8,000. Median 2-car install on the standard mid-tier in the GTA is landing around $4,200-$4,800 this season, which matches what most homeowner-facing pricing pages have been quoting.
Add-ons we see priced separately on a written quote:
  • Disposal of old surface: $200-$600 for asphalt, $400-$1,200 for concrete (heavier, more expensive bin).
  • Curb cut or sidewalk crossing: depends on municipality. Toronto curb cut permit is a separate City application, usually $400-$900 in 2026 fees plus the contractor’s labour.
  • Reinforcing the apron at the road edge: extra 2 inches of base + thicker asphalt at the curb-side 4 feet, $150-$400.
  • Extending the existing driveway (rather than full replace): add the linear-foot pricing, usually 10-15% cheaper than full replace because the existing base is reused at the join.
Asphalt vs concrete vs interlock: what the install-stage choice actually costs
This is the comparison that drives the May decision for most GTA homeowners. The numbers below are spring 2026 GTA install-side, not lifecycle:
  • Asphalt: $4-$10 per sqft installed. Lasts 15-20 years with seal-coat maintenance. Repairs blend in well. Heat shows through; on hot summer days the surface softens. Black aesthetic.
  • Concrete: $10-$15 per sqft installed for plain finish, $14-$22 per sqft for stamped or coloured. Lasts 30-40 years on a properly built slab. Cracks are the main failure mode and they are visible. The decision tree on concrete vs interlock is in our interlock vs concrete driveway thread which has the long-form lifecycle math.
  • Interlock pavers: $20-$30 per sqft installed for a typical residential layout. Lasts 25-40 years if built properly with a deep aggregate base. Individual paver replacement is possible (asphalt and concrete cannot do this). Joint sand needs refresh every 3-5 years and sealing is its own decision (we covered the sealing side at GTA interlock paver sealing spring 2026).
If somebody is asking “should I replace my asphalt with concrete or interlock,” the budget answer is usually that asphalt-on-asphalt is the cheapest path and concrete-on-concrete is the longest-lasting. The middle decision (asphalt now, interlock in ten years) is usually dictated by cash flow, not by aesthetics, and that is fine.
If the existing driveway is concrete and starting to fail, repair-vs-replace is its own conversation. We have a separate write-up for that situation at concrete driveway repair Ontario: resurface or full replacement.
The seal coat: when to do it and when not to
The first seal coat is one of the more confused topics in residential paving. The general rule is:
  • Year 1: do not seal. New asphalt needs to off-gas its lighter oils for 6-9 months minimum, sometimes 12 months in cooler climates. Sealing a fresh driveway traps those oils, leaving a soft surface that will rut under tire weight.
  • Year 2: seal in late spring or early summer once the surface has gone from glossy black to matte black-grey.
  • Year 3 onward: seal every 3-4 years. Twice-a-year sealing does not extend life; it just builds up coats that crack in their own pattern.
If a paving contractor is offering to seal the driveway “the day after we pour” as a value-add, that is a red flag. Either they are using a sealer that is genuinely safe to apply on fresh asphalt (uncommon, expensive, and almost never the case on a budget quote) or they are accelerating a problem by 18 months.
Sealer choice matters too. Coal-tar emulsion is the longest-lasting (8-10 years between applications) but is being phased out in many Ontario municipalities for environmental reasons. Asphalt emulsion is the standard residential alternative (3-5 years between applications). We see some homeowners going with acrylic-modified sealers, which last 5-6 years and tend to keep their black colour better but cost 30-50% more per gallon.
Five questions to ask before signing the quote
  1. What is the dig depth and what aggregate goes in the base? A real answer is 12-15 inches and Granular A. A vague answer (“we’ll prep the base”) usually means corners are getting cut.
  2. Single lift or two lifts of asphalt, and what is the total finished thickness? Real answer is 3 inches finished, single or two-lift specified, with HL-3 or HL-3A grade.
  3. Is disposal of the old surface in the quote, or is that extra? Both are fine; ambiguity is not.
  4. What is the warranty, and what voids it? Most reputable GTA installers offer 1-2 year workmanship warranties. Driving heavy equipment on it before cure, sealing in year one, or installing landscaping that holds water against the edge usually voids it.
  5. Are you ESA-licensed for any electrical work (heated driveway, integrated lighting, EV charger pad)? Mostly relevant for upscale jobs, but it is a quick filter on whether the company is set up for code-side work.
Companion spring 2026 reading on home.renovation.reviews
If you are weighing material options for a driveway tear-out this spring, these are the threads that pair with this one:
Bottom line by use case
  • Standard 2-car asphalt replacement, single-lift, mid-tier GTA contractor: budget $4,200-$5,500. Plan for late May or early June. Seal in year two.
  • Long lane (>800 sqft) or sloped driveway: spec two-lift hot mix, expect $7-$9 per sqft. Get the site visit before signing.
  • Asphalt over existing asphalt (resurface, not replace): only viable if the existing base is sound and the surface failure is purely top-layer. Saves 30-40% vs full tear-out. We say yes to this maybe one out of four times we see it asked about.
  • Asphalt for an EV-heavy household: still fine. The myth that EV weight cracks asphalt is overstated; a Model Y is no heavier than a 1999 Suburban. Heat from a hot battery pack on a fresh July install is the actual concern, and that goes away by year two.
  • Heated driveway integration: possible with hydronic loops in the base, but expect to add $20-$35 per sqft and an ESA-permitted electrical run. We almost never recommend this for an asphalt driveway in the GTA because asphalt’s temperature limits make the heating system harder to control. It is much more common over an interlock paver setup.
We have been doing GTA paving and hardscape work for more than fifty years, and the question we get most often is still “is my quote fair.” The honest answer is that fairness depends on what is in the base, not what is on top. Read the second page of the quote, not the first.
If this thread saved you from a flyer-pitch quote, helping us out by helping the next homeowner is what keeps the forum running. Helpful posts on home.renovation.reviews earn $RENO, the community’s Solana-issued token, with tier-up badges and rewards tracked publicly on the $RENO leaderboard and the public payment ledger. Linking a Solana wallet on signup unlocks the airdrop and tier-up rewards.
