Interlock vs concrete driveways in Toronto: the honest comparison
One of the most common questions from GTA homeowners considering a driveway project. Here is a straight answer based on what we have seen from thousands of driveway and pathway projects over 50 years in the Toronto area.
Interlock Pavers
Advantages:
  • Individual stones can be replaced if damaged — a genuine long-term advantage in our climate
  • Handles Toronto’s freeze-thaw cycles better than solid slabs over 20+ years
  • Hundreds of pattern, colour, and texture combinations
  • Better drainage options including fully permeable interlocking systems
  • Generally higher curb appeal and resale value
Disadvantages:
  • Higher upfront cost vs plain concrete (typically $30–$45/sqft vs $10–$18/sqft for a standard poured driveway in 2026)
  • Requires maintenance every few years: polymeric sand top-up, edge restraint checks
  • Settles unevenly if base preparation was inadequate — but this is an installation quality issue, not a material flaw
Poured Concrete
Advantages:
  • Lower initial cost for a standard residential driveway
  • Clean, minimal aesthetic that suits modern and contemporary exteriors
  • Durable and low-maintenance when properly installed with expansion joints
Disadvantages:
  • Cracks are permanent — any repair is always visible as a patch
  • Toronto winters are hard on solid slabs: salt damage and freeze-thaw cracking are common after 8–15 years
  • When concrete fails it must come out as a full slab; you cannot swap individual sections the way you can with interlock
Cost Comparison for Toronto in 2026
Material Typical installed cost (GTA) Expected lifespan (well-maintained)
Interlock pavers $30–$60/sqft 25–40 years
Poured concrete $10–$18/sqft 15–25 years
Stamped concrete $20–$35/sqft 15–20 years
The upfront gap is real, but the per-year cost often evens out when you factor in full-slab concrete replacement — and the disruption that comes with it.
The Toronto Climate Verdict
Interlock is almost always the better 20-year investment for GTA climate. The ability to replace individual stones is a genuine advantage when you consider what -25°C winters and road salt do to fixed concrete slabs over time.
The single most important factor in interlock longevity is base preparation — a 6–12 inch compacted Granular A base with geotextile fabric and proper edge restraints installed in 2–3 inch tamped lifts. The pavers themselves are just the visible layer. A well-installed interlock driveway on a proper base will outlast most poured concrete in this climate.
For the full breakdown on base-preparation standards and what to ask contractors before signing, see: The 12-inch rule: why most Toronto interlock patios fail by spring.
What has your experience been? Interlock or concrete — which have you had better luck with in the GTA? Drop a reply below.
LF Builders | 50+ years of interlock, flagstone, and driveway work across the GTA — get a quote | home.renovation.reviews
Samm Simon’s 251 km charity run for cancer research is raising funds for cancer research — LF Builders is proud to support it. For more renovation guides and how-tos, visit the LF Builders renovation blog.
Adding to this from field experience — the spring timing factor is worth highlighting right now.
April and early May is prime driveway replacement season in the GTA, but it also brings a few complications. The ground is still coming out of freeze-thaw and in some areas the water table is elevated. Any contractor rushing to install in late April before conditions stabilize is doing you a disservice on the base prep side.
For interlock specifically, what we look for before starting:
  • Ground temperature consistently above 5C so the granular base is not frost-affected
  • At least one good rain cycle after winter so drainage patterns are visible — if you have low spots that pool, that needs grading attention before any surface goes in
  • Edge restraints confirmed to be going below finished grade, not sitting on top
On concrete: we still install it for clients who want it, but always with reinforcement (fibre-mesh at minimum, rebar on wider sections), control joints every 8-10 feet, and a sealer applied the first fall. Skipping the sealer after year 1 is the most common mistake that leads to the salt and spalling damage you see on 5-year-old concrete driveways.
One thing we have noticed in the last couple of years: the gap between interlock and concrete pricing has narrowed as labour costs have risen for both. If you are comparing quotes, make sure you are comparing the same base depth. A quote with a 4-inch base is not comparable to a quote with a 6-inch base — the surface is the visible part, but the base is where the money matters.
What city are you in? Installation approach and drainage context can vary quite a bit from Toronto proper vs the suburbs.
