GTA Polymeric Sand Refresh Spring 2026: When Interlock Joints Need Topping Up, How It's Done Right, and Real Costs
If you have an interlock driveway, walkway, or patio in the GTA, the joint sand is doing more work than most homeowners realize. It locks the pavers laterally, sheds surface water away from the base, and stops the freeze-thaw cycle from prying individual stones loose. By year three or four, you usually start seeing thin spots — joints that look low, dark hairline gaps, weed sprouts, or ant cones in mid-summer — and that is the signal that a polymeric sand refresh is overdue.
Spring 2026 is the right window for this in the GTA. The frost has lifted, the surface is starting to dry, and there is a long enough run-up of warm, dry days through May and into early June to do the work properly. This thread is a contractor-side walkthrough of when a refresh is actually warranted, the right way to install polymeric joint sand on existing interlock, what it costs in the spring 2026 GTA market, and the mistakes that turn a $400 weekend project into a $3,000 redo a year later.
When polymeric sand actually needs to be refreshed
Three honest tests before you spend a dollar:
The dime test. Drop a Canadian dime into a joint. If the dime sits at or below the chamfer of the paver edge, the joint is more than the recommended 1/8 inch under the surface and the sand is depleted. If the dime stands proud above the surface, the joint is fine and you do not need a refresh.
The probe test. Push a flathead screwdriver into the joint at several locations. Loose sand to a depth of more than about half an inch means the joint binder has failed and a top-up alone will not hold. That joint needs a full clean-out and re-sand, not a sweep-in.
The growth test. Active weed germination, moss, or ant cones in the joint line all mean water is finding the base. Once you have biological activity, no amount of new sand sitting on top of the old sand will stop the next round.
If your interlock passes the dime test and the probe test, leave it alone. A perfectly intact polymeric joint is a 7-to-10-year part on a residential driveway in the GTA. Topping up sand that does not need topping up wastes the product and creates a weak surface layer that hazes the pavers.
Spring 2026 weather window in the GTA
Polymeric sand is the fussiest hardscape product on the market when it comes to weather. The standard manufacturer envelope is air temperature above 35°F (about 2°C) for at least 48 hours after activation, no rain in the 24 hours before installation, and no rain forecast for at least 24 hours after the activation water. Cool, damp, overcast days extend the cure time. Below freezing during the cure window is a write-off — the polymer will not bind and you will have to remove every joint and start over.
Practically that gives most GTA homeowners a working window from roughly the second week of May through the first week of November, with the cleanest installs happening in the dry stretches of late May, June, and September. The spring storm cycle that ran through late April this year (the same one driving the May 1 basement-flooding subsidy bump and the wet-season checklist work in April 2026 GTA Flooding: 4 Home Checks to Run Before the May 1 Subsidy Deadline) has left a lot of interlock surfaces saturated. Wait for at least three consecutive dry days with daytime highs above 12°C before you start.
How a proper refresh job is done
A real refresh — not a sweep-in — is a four-stage job:
Stage one is full joint clean-out. You remove the old sand to a minimum depth of one inch using a joint cleaner, a flat screwdriver, or a power blade on a small angle grinder for stubborn polymer remnants. Skipping this step is the single biggest reason DIY polymeric jobs fail. New polymeric on top of old polymeric does not bind chemically; it sits as a powder layer that the first heavy rain washes out.
Stage two is thorough surface dry. Polymeric sand has to go into a bone-dry joint. Any residual moisture in the joint or on the paver surface activates the polymer prematurely and you get hazing. After clean-out, give the surface a full sunny day to dry, then a power-blower pass to clear any sand grit from the paver tops.
Stage three is the sweep-and-vibrate. Sweep the new polymeric sand across the surface in a diagonal pattern so it falls evenly into the joints. The joint should fill to about 1/8 inch below the paver chamfer — too low and water gets to the base, too high and you cannot wash the residue cleanly off the paver tops. A plate compactor with a rubber mat (not bare metal) over the surface settles the sand and reveals low spots that need a second sweep.
Stage four is activation. Use a fine mist nozzle on a garden hose, never a stream. Wet the joints in two to three light passes, allowing the water to penetrate down through the full one-inch joint depth without flushing sand out. Stop the moment standing water appears in the joint. Walk off and do not touch the surface for 24 hours minimum, ideally 48 to 72 in cool weather.
For a step-by-step on the underlying interlock build-up itself — base depth, paver thickness, edge restraints — the Pickering Unilock Beacon Hill driveway walkthrough is a useful companion thread; it covers how the joint sand sits inside the broader system.
Real spring 2026 GTA costs
Bag price for a quality polymeric sand at GTA retail (Toemar, Permacon, Techniseal, Alliance Gator) is running $32 to $48 per 50-pound bag in spring 2026. Coverage depends on joint width and depth, but a typical residential driveway with 3-to-5-millimetre joints needs roughly one bag per 80 to 100 square feet of paver surface for a top-up, or one bag per 50 to 65 square feet for a full clean-out and re-sand.
DIY material cost for a 600-square-foot driveway runs $250 to $600 depending on bag count and brand. Add $40 to $80 for a joint cleaner, mist nozzle, and a couple of stiff-bristle brooms.
Hiring it out: the spring 2026 GTA market is sitting at $1.50 to $3.50 per square foot for a clean-out-and-resand on residential interlock, depending on access, condition, and whether the contractor is also pressure-washing or sealing. On a 600-square-foot driveway that lines up to roughly $900 to $2,100 all-in. A quote materially higher than that, on a clean refresh-only scope with no edge restraint repair or paver re-lift, deserves a second opinion.
If the contractor is bundling a full sealer top-coat after the polymeric cures, expect another $2 to $5 per square foot per the same 60-to-90-day cure rule that applies to new installs. The longer thread on when sealing is and is not worth the money is at GTA Driveway Sealing Spring 2026: When to Seal, When to Skip, and Real Costs.
DIY vs hiring out
The honest break-even sits around 400 square feet. Below that, a careful homeowner with a free Saturday, a good weather window, and a willingness to follow the weather rules above can do a refresh for $300 to $500 in materials and walk away with a result that holds for five-plus years.
Above 600 square feet, or anywhere with complex curves, multiple grade changes, or pavers that have shifted laterally, hiring it out is almost always the right call. The clean-out time scales non-linearly with size, and the activation-water step on a large surface gets unforgiving fast — over-water one section and you have a haze problem; under-water another and the polymer never binds.
The middle band — 400 to 600 square feet, simple geometry, intact pavers — is genuinely a coin flip. The rule of thumb on this site is: if the surface has any settled or wobbly pavers, do not refresh-only. Lifting and resetting those stones first is the actual job; the new sand is just the finishing touch.
Common refresh mistakes
Sweeping new polymeric over old polymeric without clean-out. Failure mode: powder layer washes out within a year.
Activating in direct hot sun without misting in stages. Failure mode: top crust forms before the lower joint hydrates; cracking within weeks.
Soaking the surface with a regular hose stream. Failure mode: sand washes out of the joints before it activates.
Doing the work below 5°C ambient with a cold front coming. Failure mode: polymer never binds, no recovery; full redo next season.
Skipping edge restraints. Failure mode: pavers spread laterally over time and the new sand cannot keep up with widening joints.
How this fits the rest of your interlock care
Polymeric sand refresh is one item in a four-part interlock maintenance rhythm: refresh joints (every 5-7 years), check and reset shifted pavers (as needed), refresh edge restraints (every 8-12 years), and decide whether to seal (situational — see the sealing thread linked above). The companion piece on the broader spring contractor-call decision tree is at Your Spring GTA Home Checklist: 8 Things to Check Before Calling a Contractor, and the bigger interlock-versus-other-surfaces material decision sits in Interlock vs concrete driveways in Toronto: the honest comparison.
Bottom line
Run the dime test and the probe test before you spend anything. If the joints fail one of them, do a full clean-out-and-resand in a dry late-May or June window, follow the manufacturer’s water-application rules to the letter, and budget $250-$600 DIY or $900-$2,100 pro for a typical 600-square-foot driveway. Done right once, this is a 5-to-7-year part on residential interlock in the GTA. Done badly, it is a $3,000 redo and a damaged paver surface.
Track $RENO earnings on this topic — interlock owners and trades who add real GTA experience are tier-up candidates. Welcome to $RENO — Quests, Rewards, Leaderboard walks through the mechanics. Link a Solana wallet on signup to claim earnings when on-chain settlement opens.
From LF Builders
Interlock installation and restoration is one of LF Builders’ core services — we have been laying and refreshing interlock across the GTA for over 50 years. For a polymeric sand refresh quote or a full interlock assessment this spring: lfbuilders.ca. Samm Simon, connected to the LF team, is running 251 km for cancer research — contributions to this thread support both better GTA interlock knowledge and the cause.
