GTA Asphalt Driveway Crack Filling Spring 2026: The Late-Spring Window, Cold-Pour vs Hot-Pour, DIY Reality, and When the Crack Is Past Filling
Every May we get the same wave of calls. Homeowner walks the driveway the first weekend the lawn dries out, sees three or four cracks running across the asphalt that did not look that bad in November, and wants to know whether to fill them this weekend or wait. May in the GTA sits at the back edge of the workable window for asphalt crack filling. Homeowners who get good results in May are usually the ones picking a cool morning, a product matched to the actual crack width, and cracks that are still narrow enough to bond. The ones who treat it like a summer job often watch the filler bubble up and pull away within six weeks.
What follows is how we think about asphalt crack repair calls in the GTA in spring 2026, written for homeowners who missed the early-April window and want to know what is still worth doing before summer locks the call out for another year.
Why May is the back edge, not the middle, of the crack-filling window
The polymer-modified rubber and emulsion blends that go into modern crack fillers cure by bonding to a clean, dry, cool asphalt surface. The temperature window most manufacturers print on the bottle reads ten to thirty degrees Celsius for both air and pavement surface. That sounds wide. In the GTA from late March through mid-April it is a comfortable window most days. By the second week of May it gets narrower fast.
The catch is pavement temperature, not air temperature. A south-facing asphalt driveway in Toronto on a cloudless eighteen-degree afternoon in mid-May can hit pavement temperatures of twenty-eight to thirty-four degrees in direct sun by two in the afternoon. Above thirty the asphalt pores open and the filler cures before it has fully wicked into the crack walls. You end up with a bead sitting on the surface that looks fine for a week and then peels off as the slab thermally cycles. In May the play is to fill in the morning while the pavement is still cool from overnight, or to fill on overcast days when the surface stays under twenty-five all day.
The other issue is moisture. Cracks that look dry on top often have damp walls a quarter inch in. If you fill a crack with even slightly damp walls in the cooler shoulder season, the filler will not bond and the next freeze-thaw cycle will pop it out. May does have its share of rainy weeks, so the pre-fill check is to make sure the crack has been dry for at least forty-eight hours. A leaf blower run along the crack will tell you fast whether you are seeing dry asphalt or damp asphalt under the dust.
Reading the cracks before you reach for a product
Asphalt fails in patterns and the pattern is the diagnosis. We see four common ones in GTA driveways and they each demand a different response.
Hairline cracks are the easiest. These are surface cracks under one-eighth of an inch wide that follow a fairly straight line, often running parallel to a driveway edge or following an old expansion joint. They are usually thermal stress cracks. Cold-pour crack filler handles these easily and the bond will last several seasons if applied right.
Linear cracks run wider than one-eighth and up to half an inch across, often with a clear path that traces a stress line in the slab. These are the bread and butter of crack filling. Cold-pour rubberised filler in a squeeze bottle works for the narrow end of this range. Anything wider than three-eighths of an inch wants either hot-pour rubberised filler or a backer rod followed by cold-pour over top, because raw cold-pour shrinks too much in a wide crack to seal it.
Alligator cracking is the pattern where the asphalt surface looks like the back of an alligator, with a network of interconnected cracks forming small rectangles. This is not a crack-filling problem. It is a base failure or a sub-surface drainage problem. Filling alligator cracks with cold-pour or hot-pour gives you maybe a season of cosmetic improvement before the underlying failure pushes through again. On alligator patterns, the call is patch-and-overlay or full removal and replacement, and filling is a waste of money.
Edge cracks running parallel to a driveway edge tell you the base under the edge has eroded or the lateral support has given way. Filling can buy time but the longer fix is to address the edge condition itself, often with a concrete edge restraint or a re-cut and re-edged repair. Treat edge cracks as a signal that the base needs attention, not as a defect to be filled.
For homeowners who want a broader frame on what their driveway is and how it was supposed to be built, the GTA Asphalt Driveway Install Spring 2026 write-up covers what hot mix versus cold mix delivers, what proper base prep looks like, and where shortcuts in the original install show up later as cracks.
Cold-pour versus hot-pour: what each is actually for
Cold-pour crack filler is the DIY product. It comes in a squeeze bottle or a one-gallon jug with a pour spout. It is rubberised emulsion that is liquid at room temperature and cures by water evaporation and oxidation over twenty-four to seventy-two hours depending on humidity. It works best on cracks under three-eighths of an inch wide. It is forgiving to apply and it cleans up with water if you get it on something it should not be on. Real-world durability runs two to four seasons in the GTA before the same crack needs to be re-filled. Material cost runs roughly fifteen to thirty-five dollars per gallon at most home centres, with a gallon covering somewhere between eighty and one hundred and twenty linear feet of typical hairline-to-quarter-inch crack.
Hot-pour rubberised filler is the professional product. It comes in solid blocks of asphalt-rubber compound that you melt in a melter kettle to roughly one hundred and seventy-five degrees Celsius before applying. It bonds aggressively to the crack walls, fills wider cracks reliably, and lasts five to ten seasons when applied at the right temperature on properly prepped pavement. It is also genuinely dangerous to apply without the right equipment and a clear understanding of what hot rubber does to skin if it splashes. We do not recommend hot-pour as a DIY job for homeowners. The melter kettles cost two to four thousand dollars, propane-fired versions add open-flame risk, and the compound itself causes immediate severe burns on contact. If your driveway needs hot-pour, it is a contractor call, not a Saturday project.
The middle ground that some homeowners reach for is a propane torch with cold-pour. This is not the same as hot-pour. Heating cold-pour with a torch helps it self-level into the crack but does not change its underlying chemistry. It looks better on day one. It does not last meaningfully longer than cold-pour applied at room temperature on a properly prepped surface.
Prep is most of the job
The single biggest predictor of a crack fill that lasts versus a crack fill that fails is what happens before any filler comes out of the bottle. Prep is most of the job and it is the part homeowners cut shortest.
Start by clearing every piece of vegetation, soil, and old filler residue out of the crack to a depth of at least the crack width itself. A flathead screwdriver works for narrow cracks, a stiff wire brush works for medium cracks, a small angle grinder with a wire wheel works for serious cleanup. The crack walls have to be clean asphalt for the filler to bond.
Once the crack is mechanically cleaned, blow it out with compressed air or a leaf blower set to high. The goal is no visible dust in the crack. Dust acts as a release agent between the filler and the crack walls, so any dust left behind sets the bond up to fail.
If the crack has been damp inside, give it forty-eight hours of dry weather before filling. Some installers will run a propane torch lightly along the crack to drive out residual moisture. This works on shallow cracks but is risky on deeper cracks where you can scorch the asphalt walls and reduce bond. The better play is to wait for the weather window.
Skip the prep step and you will see your work on the driveway again next spring.
The actual fill: what works on a Saturday morning
Pick a morning where the overnight low was above five degrees Celsius and the daytime high is forecast under twenty-five. Start by nine, finish by noon. Pavement temperature should be cool to the touch when you start.
Apply cold-pour filler in slow continuous beads with the tip of the bottle riding inside the crack, not above it. Overfill slightly so the cured surface sits proud of the crack by a sixteenth of an inch, because cold-pour shrinks as it cures. For wider cracks beyond three-eighths of an inch, push a foam backer rod into the crack first to a depth of about half the crack width, then pour cold-pour over top. The backer rod gives the filler something to push against and prevents it from running through the crack to the base.
Tool the filler with a narrow putty knife or a small piece of plywood drawn along the crack at a forty-five-degree angle. The tooling pass should compress the filler into the crack walls and leave a smooth crowned bead on top. Some installers skip tooling entirely and let the filler self-level. That works on hairline cracks but leaves a less durable surface on anything wider.
Cure time depends on humidity. Most cold-pour formulas list four to six hours to walk-on, twenty-four hours to drive-on, and seventy-two hours to fully cured. Cars driving on uncured filler will print tire tracks and reduce long-term bond. Block the driveway for at least the manufacturer-stated drive-on window.
Cost bands you should expect
For DIY application, plan on twenty-five to fifty dollars in cold-pour material for a typical two-car driveway with five to ten cracks under a quarter inch wide. Add ten to twenty dollars for a backer rod if you have wider cracks, plus the cost of a wire brush and a putty knife if you do not already own them. Total all-in for a competent DIY job sits comfortably under one hundred dollars.
Pro crack-filling quotes in the GTA in spring 2026 run two-fifty to six-hundred dollars for a typical driveway with cold-pour, and four-fifty to twelve-hundred dollars for hot-pour on the same driveway. Most reputable contractors will not come out for less than a two-fifty minimum because mobilisation cost dominates a single-driveway visit. Crack filling that gets bundled with sealcoating typically runs in the lower end of that range because the contractor is already on site.
There is a band above that for serious work. Driveways with extensive linear cracking, multiple wide cracks, or a need for both filling and a follow-up sealcoat can run twelve-hundred to twenty-five-hundred dollars done right. Beyond that band the conversation is no longer about filling. It is about resurfacing or replacement and you should be evaluating the slab as a whole.
When the crack is past filling
There are conditions where filling is the wrong call regardless of how good the product or the prep is. Knowing those conditions saves you the cost of a repair that will not last.
Alligator cracking covering more than ten percent of the driveway surface points to base failure that filling will not address. Cracks wider than one inch typically have lost the bond at the crack walls and will not hold filler reliably. Cracks that telegraph through a previous fill within twelve months indicate movement faster than filler can absorb. Cracks running through a settled or sunken section of driveway are a settlement problem first and a crack problem second. And any crack that shows white efflorescence or active water seepage during a rain event is a drainage issue that filling will not solve.
For homeowners thinking about the longer maintenance arc, the GTA Driveway Sealing Spring 2026 write-up covers the timing question on follow-up sealcoats after crack filling, and the Ontario Driveway and Interlock Guide 2026 covers the broader question of when an aging asphalt driveway is past the point of patching and into replacement territory.
A quick decision rule for May
If you have under a dozen hairline-to-quarter-inch linear cracks on a driveway that is still structurally sound, fill them on a cool May morning with cold-pour and you will get good results. If you have wider cracks but a sound base, hire a contractor for hot-pour and skip the DIY route. If you have alligator cracking, settlement, or active water issues, the filling decision is the wrong question and you should get a contractor opinion on the slab as a whole before spending money on filler that will fail.
May in the GTA is not the perfect window. It is the late but workable window. The homeowners who treat it that way get the result they want.
If you have a driveway photo or a specific crack pattern you want a second opinion on, post it as a reply with a picture and someone in the community will tell you what they see. The forum runs on a community currency called $RENO that gets earned by contributors who take the time to give a real answer. Top contributors over the past month sit on the leaderboard, and the welcome topic walks through how the token works and how to link a Solana wallet to your profile.
I tell you I really did take my time going through this and I’ll tell you it was really worth it. You’re doing a fantastic work boss honestly
