Velux skylight installation in our Kitchener bungalow — dark hallway problem solved
Our Kitchener bungalow had a central hallway with no natural light. You walked from the bright kitchen into a dim tunnel to get to the bedrooms. One Velux fixed skylight solved it completely.
The problem:
Central hallway, 4 ft wide, 18 ft long, no windows possible (flanked by bedrooms on both sides). The only solution was either a light tube (tubular skylight) or a full skylight with a shaft.
What we considered:
Option A: Tubular skylight (10-inch Velux Sun Tunnel)
  • Pros: minimal framing, low cost
  • Cons: light quality is diffused and not as natural; 10-inch tube in an 18-ft hallway would be underwhelming
Option B: Fixed skylight (Velux FS C04, 21x46 inches) with splayed drywall shaft
  • Pros: dramatic natural light, excellent light quality
  • Cons: requires framing the shaft, more drywall, higher cost
We chose Option B.
Installation:
  • Skylight opening cut in roof (between existing rafters — no rafter modification needed for this size)
  • Ice and water shield around entire perimeter
  • Velux aluminum flashing kit installed
  • Splayed drywall shaft framed (wider at ceiling than at skylight — maximizes light spread)
  • Painted the shaft white for maximum reflection
Cost:
  • Skylight (Velux FS C04): $820 supply
  • Roofing contractor (cutting, flashing, shingles): $1,400
  • Framing and drywall shaft (carpenter + drywaller): $1,600
  • Paint and trim: $220
  • Total: $4,040
The hallway now: Looks like a completely different space. The splayed white shaft acts as a light amplifier — even on overcast days, the hallway is well-lit. Zero leaks through our first full year including a severe ice dam event.
