If you live in the City of Toronto and your downspouts still empty into a pipe that disappears into the ground next to your foundation, you are out of compliance with a bylaw that has been on the books since 2011, and you are very likely the reason your basement floods in a heavy storm. Disconnection is not optional. It is also not complicated, but the small details on the work are the difference between a clean fix and a job that creates a new water problem two metres from your foundation wall.
This guide walks through what the bylaw actually requires, how to tell whether your house is still on the wrong side of it, what the DIY job involves step-by-step, when to bring in a contractor instead, what disconnection should actually cost in spring 2026, and how this work relates to the Toronto Basement Flooding Protection Subsidy.
Why Toronto made downspout disconnection mandatory
Toronto’s combined and partially-combined sewer system was designed for a city of about half its current population, with far less paved surface than the city has today. When a heavy rainfall hits, every downspout still tied directly into the sewer is dumping concentrated roof runoff into a pipe network that is already loaded with sanitary flow. The result is the pattern Toronto homeowners know well: surcharged sewers, basement back-ups, and combined sewer overflow into the lake.
The Mandatory Downspout Disconnection bylaw was the city’s response. It is administered under the Property Standards Bylaw (Toronto Municipal Code Chapter 629-20, Roofs and Roof Structures) and requires every property owner — residential, commercial, institutional — to disconnect downspouts from the city sewer and direct stormwater onto the property instead. The original phased deadlines passed years ago. As of the end of 2013, City-wide compliance was the legal expectation. The City has historically taken a soft-enforcement posture for owners making a genuine effort to comply, but a still-connected downspout becomes a hard problem the moment your insurer asks about loss-prevention measures after a basement flood claim.
For the technical reasoning behind the bylaw, see the Wet Weather Flow Master Plan referenced in the city’s broader stormwater work. For the homeowner-side action checklist, the GTA flooding: 4 home checks before you apply for Toronto’s basement flooding subsidy thread covers the broader storm-prep picture, of which disconnection is one piece.
Where your downspouts are likely still connected — a five-minute self-audit
Walk the perimeter of your house with a pair of work gloves and look at every downspout where it meets the ground. There are three patterns:
The downspout terminates above grade with an elbow and a flexible or rigid extension carrying water away from the foundation, and you can see daylight under it. Disconnected — compliant.
The downspout vanishes into a vertical clay or PVC standpipe that comes up out of the ground next to your foundation, with no extension visible above grade. Almost certainly still connected to the city sewer. This is the most common configuration on pre-1980 Toronto and inner-suburb housing stock.
The downspout enters a buried elbow that turns horizontally into your foundation wall above grade, with no above-ground termination. Connected, possibly through your weeping tile or interior plumbing. This is the highest-priority case to fix because it can cause water in the basement directly, not just sewer overload.
If you find a Pattern 2 or Pattern 3 configuration, count the downspouts. Most Toronto detached houses have four to six. Each one is a separate disconnection job, but most homeowners fix them all at once because the materials and labour are nearly identical per spout.
The DIY downspout disconnection — what the work actually is
This is genuinely a Saturday-afternoon job for two people on a typical bungalow if your downspouts are accessible from the ground or a short stepladder. The City of Toronto’s own how-to is simple and accurate; the following is the same flow with the failure modes our crews see in the field flagged inline.
You need a fine-blade hacksaw, a tape measure, a metal file, a hammer, a drill, sheet-metal screws, a downspout elbow, a downspout extension (rigid or flexible — rigid lasts longer in the GTA freeze-thaw), a rubber or PVC cap with a hose clamp to plug the standpipe, splash pads, brackets to secure the new run to the wall, and protective gear.
Measure 23 cm (about nine inches) up from where the downspout enters the sewer standpipe. Cut horizontally with the hacksaw. Lift the cut section out — do not let any of it fall into the standpipe. File the rough edges of the cut downspout so they do not catch on the new elbow.
Cap the open standpipe immediately. This step is the one homeowners skip and regret. An open standpipe is an open invitation for leaves, debris, mice, squirrels, and water from grading runoff to enter the city sewer through your line — which both contributes to the problem the bylaw was designed to fix and creates a fall hazard for small animals that cannot climb back out. A rubber cap with a hose clamp is the cleanest fix; a PVC cap or a wingnut test plug set in a thin concrete collar is a more permanent option.
Insert the downspout into the elbow — never the elbow into the downspout. Doing it the wrong way causes leaks at the seam every time. You may need to crimp the cut end of the downspout slightly with pliers for a clean fit. Attach a downspout extension to the elbow, again with the upstream piece inserted into the downstream piece. Cut the extension to length so the discharge point is at minimum 1.8 m (six feet) away from the foundation, ideally further. Drill pilot holes and secure both joints with sheet-metal screws so wind and ice do not separate them.
Place a splash pad under the discharge point on grass or garden soil. The splash pad spreads the impact of concentrated roof flow, prevents erosion ruts, and keeps the discharge from carving a channel back toward your foundation. Without the splash pad, on heavy clay GTA soil you will create a permanent muddy depression within one season and on sandy soil you will erode a trench within one storm.
Repeat for every downspout. Take photos before and after. The City does not require submission, but if you ever apply for the basement flooding subsidy, photos are useful documentation.
Where DIY ends and you should call a contractor
There are four scenarios where the DIY route stops working and a licensed contractor (a roofer or eavestrough specialist for most cases, a licensed plumber if the standpipe needs sealing inside the house) becomes the right answer.
The downspout enters the foundation wall above grade and continues inside, draining to either an interior standpipe or directly into the sanitary stack. This is a plumbing job, not an eavestrough job, and the standpipe needs to be properly capped inside the house with a code-compliant fitting, not just sealed outside.
The standpipe is part of a shared sewer connection with another property (common on semi-detached and row houses built before 1960). You cannot disconnect a shared standpipe unilaterally without affecting the neighbour’s drainage. A contractor will pull a building department record search to confirm the configuration before cutting.
The downspout is on a second- or third-storey wall with no safe ladder access. Roof and ladder safety is the job most likely to send a homeowner to the emergency department in this entire scope of work. The cost of a contractor for a one-day disconnection on a tall house is far less than the cost of a fall.
There is no reasonable place to discharge the water on grade. Tight side-yard setbacks under 1.5 m, sloping toward a neighbour, or a fully paved-over yard are all conditions where the disconnection itself is solvable but the discharge management requires regrading, a French drain, or a rain garden. See Ontario Foundation Grading and Drainage: The Source-First Approach to Wet Basements for what good grading looks like; if your lot does not have it, downspout disconnection alone will not protect you.
Real GTA 2026 contractor costs by scenario
Pricing for downspout disconnection in spring 2026 sits in a wide band because the work mixes a relatively cheap materials list ($25–$60 per downspout in elbow + extension + splash pad + cap + screws) with labour rates that vary by trade. Eavestrough crews quote $80–$130/hr in the GTA in 2026; licensed plumbers (needed for any inside-the-foundation work) quote $90–$150/hr standard hours and $200–$350/hr after hours, typically with a $130–$455 call-out fee that includes the first hour.
For a typical detached Toronto bungalow with four exterior-only downspouts where everything is accessible from a short ladder, expect $400–$800 for the full job from an established eavestrough crew. The high end of that range gets you 5-inch or 6-inch matched extension stock instead of generic 3-inch flex tubing, brackets that match your siding, and proper standpipe caps instead of a tin lid taped down.
For a two-storey detached with five to six downspouts and at least one second-storey downspout requiring a tall ladder or roof access, expect $700–$1,400. Add $200–$500 if any downspout needs to be relocated to find a discharge point — this is common on narrow lots where the existing downspout location dumps directly onto the neighbour’s property, which the bylaw does not allow.
For a house where one or more downspouts enters the wall above grade and continues inside (Pattern 3 above), add a separate plumber line item of $300–$700 per interior standpipe to cut, cap, and pressure-test the disconnection, plus drywall patch work if the standpipe is in finished space.
The only real way to know your number is to get three written quotes. Be wary of any quote that comes in dramatically lower than the others — the most common short-cut is to skip the standpipe cap or to use a fitting that fails the first winter. The historical $1,300 figure that gets quoted in older media coverage is the city’s 2007 average across all property types; for a typical 2026 single-family home with no interior plumbing involvement, the real number is half that or less.
Financial assistance and the exemption process
The City offers a financial assistance program that reimburses up to $500 of disconnection costs (labour and materials) for eligible low-income seniors and eligible low-income people with a disability. The application is processed by Toronto Water; the eligibility criteria and form are on the City’s downspout disconnection page.
A formal exemption is available where disconnection is genuinely not feasible. Common grounds: the discharge point would create a hazard (e.g., a sidewalk that ices over, a driveway that becomes slippery), or the property layout makes it physically impossible to direct water away from neighbouring property. Before the exemption application is approved, the City expects you to show you have made every reasonable effort to disconnect — relocating downspouts, regrading eavestroughs, fixing the slope. The application requires a property sketch showing every downspout, the proposed discharge points, and the reason each is unworkable. Exemptions are decided per downspout, not per house — partial exemptions are common.
If your downspout configuration is unusual, file the exemption application even if you also intend to disconnect what you can. Having the application on file documents your good-faith effort.
How downspout disconnection relates to the basement flooding subsidy
A point of confusion worth flagging early: the cost of downspout disconnection itself is generally not reimbursed under the Toronto Basement Flooding Protection Subsidy. The subsidy covers the protective hardware — backwater valve installation, sump pump installation, and pipe severance and capping (severing the foundation drain from the sanitary lateral) — and reimburses up to 80% of eligible costs to a per-property cap of $6,650 (since May 1, 2026, for work completed on or after November 12, 2025). Disconnected downspouts, or an exemption, are still a condition of the subsidy, and eligible low-income seniors and people with disabilities can get up to $500 toward the disconnection itself. Disconnection sits outside that envelope because the City treats it as a baseline compliance obligation under the existing bylaw, not an upgrade.
That distinction matters for sequencing. The strongest pattern we see on full-stack basement flood protection work in the GTA is: get the property’s existing drainage configuration documented; do the downspout disconnection and any required regrading first as the homeowner-paid baseline; then file for the subsidy on the backwater valve and sump pump work as the protective layer for the sewer-side risk that disconnection alone does not solve. The Toronto Basement Flood Subsidy May 1 2026 Step-by-Step Filing Guide walks through the application paperwork in detail, and the GTA Backwater Valve Installation 2026 thread covers the protective-layer side.
The mistake we see most often in the field on this sequencing: homeowners go straight to the most expensive line item (the backwater valve) because that is where the subsidy dollars go, while leaving downspouts still feeding the sewer that the backwater valve is now defending against. The protection still works, but you are paying for protective hardware to manage stormwater volume that you could have removed from the equation entirely with a Saturday and $40 of materials per downspout. Disconnection first, protective hardware second.
The five mistakes we see most often on Toronto disconnection jobs
The standpipe gets cut but never capped. The new downspout extension takes the roof water away, but the open pipe in the ground still funnels everything else — rain, snowmelt running across the grade, leaves, animals — into the city sewer. Defeat the entire purpose of the work.
The discharge point is too close to the foundation. Anything under 1.8 m is functionally still draining onto your foundation footing. On heavy clay, the water saturates the soil column right back to the wall and any crack or weep tile defect becomes an interior leak. Aim for 2.4 m or further and slope the receiving ground away from the house at a minimum 2% grade for the first 1.8 m.
The discharge crosses a sidewalk or driveway. The bylaw is explicit on this and it is also a winter liability — water that flashes to ice on a city sidewalk is on the homeowner’s liability. If your only available discharge route is across a hard surface, you have an exemption case to make rather than a DIY project to start.
Cheap flexible plastic extensions used as the permanent run. Black corrugated flex extensions are fine as a temporary fix but they crush, separate, and clog with leaves within one to three winters in the GTA. Rigid aluminum or vinyl downspout extension stock matched to the existing downspout colour is the durable solution and is what professional crews install.
The neighbour problem. Disconnecting a downspout that now drains onto a neighbour’s property is not a fix — it is the start of a different complaint. The bylaw and Ontario property law both require water to be managed on the originating property. If the only available discharge is toward a neighbour, the answer is regrading, a buried French drain, or a rain garden — not a new direction for the same water.
Bottom line
Downspout disconnection is the cheapest, highest-leverage piece of Toronto basement-flooding protection work a homeowner can do, and unlike most flood-prevention work it does not require a permit, an inspection, or a contractor for the typical detached house. It is also a legal requirement, not a nice-to-have. With the Basement Flooding Protection Subsidy expanded since May 1, 2026 and the storm patterns of the last three GTA springs, this is the right month to do it.
If you have not already, walk the house, count the downspouts, decide DIY-versus-contractor by the four-scenario test above, and either do the work or get three quotes. The materials list runs about $30–$60 per downspout. The labour is a Saturday morning. The downside of doing nothing is a sewer back-up that the City’s subsidy will not retroactively cover and an insurance claim that gets harder every year.
Track $RENO earnings on this topic — top contributors at the homeowner-and-trades intersection are tier-up candidates. New here? See the $RENO welcome topic and link a Solana wallet on signup so quest rewards land in your wallet automatically.
LF Builders handles drainage corrections, downspout extensions, and waterproofing across the GTA — lfbuilders.ca. LF Builders supports Samm Simon’s 251 km charity run for cancer research.
- Related: Toronto Basement Flood Subsidy May 1 2026: Step-by-Step Filing Guide
- Blog: Eavestrough & Gutter Guard Cost Guide 2026
- Renovation experts: lfbuilders.ca — 50+ years serving the GTA
- Charity: Samm Simon’s 251 km run for cancer research
Corrected Oct 30, 2026 to match the City of Toronto’s Basement Flooding Protection Subsidy page.
