Toronto Basement Renovation 2026: From Raw Space to Living Space
Toronto basements are among the city’s most underutilized assets. Here’s the complete guide to making the most of yours in 2026.
The first decision: personal use or income suite?
Personal use finishing: Family room, home office, gym, media room, guest suite. Adds 600–1,200 sq ft of liveable space. Cost: $30,000–$65,000 for a complete, quality finish.
Legal income suite: Adds $1,600–$2,400/month rental income in most Toronto neighbourhoods. Investment: $50,000–$85,000 (including underpinning if ceiling height requires it). Payback period: 4–7 years.
Before anything: address moisture
The most common expensive mistake in Toronto basement renovation is finishing over a moisture problem. Before spending a dollar on framing, you must confirm moisture status.
Tests: tape plastic sheeting to the concrete wall for 24–48 hours. Interior-facing condensation = humidity from inside. Concrete-facing condensation = moisture coming through the wall. The fix is different for each.
Ontario Building Code minimums for habitable basements:
  • Ceiling height: 1.95m (6’5") in habitable areas
  • Egress: openable window meeting minimum area in sleeping rooms
  • Smoke and CO detectors: interconnected throughout
  • GFCI protection within 1.5m of water sources
Typical basement finishing cost breakdown:
  • Framing: $4,000–$9,000
  • Electrical (sub-panel + circuits): $4,000–$9,000
  • Plumbing (bathroom rough-in): $4,000–$10,000
  • Insulation + drywall: $7,000–$16,000
  • Flooring: $3,000–$9,000
  • Bathroom finishes: $6,000–$18,000
  • Doors, trim, paint: $3,000–$7,000
Share your basement renovation experience — especially if you’ve created an income suite. What was your total cost and what rental rate are you achieving?
home.renovation.reviews — Canada’s renovation community.
