Tiled our master ensuite shower in North York — large format porcelain, Kerdi membrane, full cost breakdown
Just finished our master ensuite reno in North York and want to share the tile work details since this was where we had the most contractor education.
Shower specs:
  • 36x48 inch shower base, custom mud bed
  • Walls tiled to ceiling (9 ft)
  • Large format 24x24 porcelain tile (matte, light grey)
  • Schluter Kerdi membrane for waterproofing
  • Niche cut into one wall (12x24 inches)
  • Linear drain (Schluter Kerdi-Line)
Labour cost (tile contractor only):
  • Substrate prep and Kerdi membrane installation: $1,400
  • Floor tile (mud bed, linear drain, mosaic tile): $1,800
  • Wall tile (large format, 4 walls to ceiling, niche): $3,600
  • Grouting, caulking, Schluter edge trim: $900
  • Total labour: $7,700
Materials we supplied:
  • 90 sq ft porcelain tile: $1,260 (at $14/sq ft from local importer)
  • Kerdi membrane and accessories: $580
  • Linear drain: $380
  • Grout and thin-set: $310
  • Total materials: $2,530
Grand total: $10,230
The Kerdi membrane was non-negotiable for us. Previous owner had used durock + RedGard in the main bath — it failed at the corners within 8 years. Kerdi bonded system has no such weak points.
Large format tile on shower walls: the seams between tiles are nearly invisible. Worth the premium labour cost in my view.
