Tariffs, lumber and supply costs: what every GTA homeowner needs to know before signing a reno contract in 2026
If you’ve gotten a renovation quote lately and felt like it was higher than expected, you’re not imagining it. Material costs across the GTA have been shifting meaningfully in 2026, and a big part of that story is tariffs.
Here’s what I’ve been seeing on the ground after 50 years in this trade, and what you should factor in before locking anything in.
What changed, and when
The US-Canada tariff situation that started gaining momentum in early 2025 didn’t disappear — it became the new baseline. Softwood lumber, steel, aluminum, certain tile and stone imports, and a range of hardware and fixture lines have all seen price adjustments that trickled into Canadian contractor quotes throughout late 2025 and into 2026.
We’re not talking about panic numbers, but for a mid-sized kitchen renovation or a basement finish, you can reasonably expect to see material line items that are 8 to 15 percent higher than what the same job would have quoted in mid-2024. Some specialty items, particularly imported cabinetry hardware and European tile, are running higher than that.
What this actually means for your project
Get quotes locked, not open-ended. If a contractor gives you a quote with a materials subject to change clause and no cap, push back. Ask for a fixed-price contract or a defined materials allowance with a ceiling. Open-ended material escalation clauses used to be minor boilerplate — right now they carry real risk.
Canadian-sourced materials are your friend. Domestic softwood lumber, Canadian-made cabinetry, and locally quarried stone are all buffered from the tariff surcharges hitting imported lines. For a Toronto kitchen, specifying Canadian-made semi-custom cabinets over imported boxes can save meaningful money this spring without compromising quality.
Timing still matters. Spring is the busiest booking window and the period when material demand is highest. If your scope is defined, locking a fixed-price contract now protects you from further movement. Waiting for tariff clarity that may not arrive is a harder bet.
The honest bottom line
We’ve been building in this city for over 50 years at LF Builders and lived through lumber shortages, housing booms, recessions, and supply chain crises. The current environment is manageable with good planning — but you want a contractor who’s on top of these details, not one who’s surprised by them at invoice time.
If you’re working through a reno quote right now and want a second opinion on whether the materials line looks reasonable, drop your numbers in this thread. Happy to give a straight answer.
More from LF Builders and home.renovation.reviews
To put some numbers on this for anyone budgeting right now: framing lumber is running about 5% higher year-over-year entering Q2 2026, and the US countervailing and anti-dumping duties on Canadian softwood lumber have settled at roughly 35% combined. That math does not stay neatly on the border - it ripples back into domestic Canadian pricing because mills and distributors are repricing against what they could get south of the border.
Two things I suggest every homeowner ask a contractor before signing in this environment:
First, ask whether the quote is fixed-price or subject to a material escalation clause. Many contractors are now including language that lets them adjust the final cost if lumber or steel moves more than a set percentage between contract signing and material purchase. That is not inherently unreasonable - but you need to know it is there, and you need to know what the cap on the escalation is.
Second, ask when they plan to purchase materials. A contractor who buys your framing lumber within the first week of contract signing is locking in today’s price. One who orders at the last minute is exposing you to whatever the market is doing four weeks from now.
The other category to watch is aluminum - capping, soffit, fascia, and window frames. Tariff pressure on aluminum has been less headline-grabbing than lumber, but the price movement on trim packages is real and it shows up in exterior and window quotes more than anywhere else right now.
