Switched our whole main floor to LVP — 12mm vs 8mm wear layer debate, what we found after 2 years
We replaced the main floor of our Ajax home with LVP two years ago. Before purchasing, I went deep on the wear layer vs total thickness debate. Sharing our selection process and the 2-year real-world results.
What we learned shopping:
The sales pitch at big box stores emphasizes total thickness (8mm, 10mm, 12mm). Nobody leading with thickness — it’s the wear layer that matters. Here’s the spec comparison from our shortlist:
Product Thickness Wear Layer
Big box house brand 12mm 6 mil
Lifeproof (Home Depot) 8mm 20 mil
COREtec Plus 8mm 20 mil
Flooring store mid-range 10mm 12 mil
We chose COREtec Plus 20-mil at 8mm. Cost: $4.85/sq ft supply (800 sq ft main floor). Installation: $2.40/sq ft. Total: $5,800.
Two-year review:
  • Heavy kitchen traffic: zero scratches visible
  • Two medium-sized dogs: rear nails have not scratched the wear layer (COREtec’s 20-mil is legitimately hard)
  • One dropped cast iron pan: created a small dent in the core (not the wear layer) — visible only from low angle
  • Colour/finish: still looks new
What I’d tell anyone:
Don’t let the store upsell you to a thicker product with a lower wear layer. Ask specifically: “What is the wear layer in mil?” Then compare. For residential use, 20-mil is the sweet spot between performance and cost.
