Pulled permits for our deck in Mississauga — here is the actual process and timeline
We just went through the deck permit process in Mississauga for a 400 sq ft composite deck with aluminum glass railing. Sharing the process because I couldn’t find a clear breakdown anywhere.
Application:
  • Submitted online through Mississauga’s ePlans portal
  • Required: site plan (I drew it in Google Drawings, it was accepted), deck framing plan showing joist/beam sizes, footing locations
  • Engineer’s stamp: NOT required for standard residential decks — only if over a certain size or unusual configuration
Timeline:
  • Submitted: March 11
  • Permit issued: March 28
  • 12 business days — much faster than I expected
Inspections required:
  1. Footing inspection before pouring concrete (or setting helical piers)
  2. Framing inspection before decking goes on
  3. Final inspection when complete
Cost:
  • Permit fee: $175 flat (under 50 sq m)
  • Inspector was thorough on the footing inspection — ours were 1.4m deep (we oversized slightly for peace of mind)
Contractor vs DIY:
  • We used a contractor for everything except the permit application, which I did myself
  • Total deck cost: $27,400 (Trex Transcend decking, aluminum/glass railing, aluminum posts)
Anyone else done permits through Mississauga’s ePlans? Curious if others found the portal easy to use.
