Our sump pump failed during spring melt in Markham: what happened, what we installed, and lessons
April 2025. Heavy snowmelt week in Markham. I came down to the basement on a Tuesday morning to find 3 inches of water across the entire basement floor. The sump pump had died — motor seized, no indication it was struggling.
The immediate damage: Finished basement with LVP flooring over underpad, two upholstered chairs (total loss), cardboard box storage (total loss), portable dehumidifier (total loss), and the worst: the drywall at the base of all perimeter walls was wet to 14 inches. The walls need to come out to below the waterline, dry, treat, and rebuild.
Insurance claim: The damage qualified as sudden and accidental equipment failure — covered. Claim paid out at $28,400 minus our $1,000 deductible. Restoration company (ServPro) did the drying and wall removal, we are handling the rebuild ourselves.
What we installed:
  1. New primary pump: Zoeller M57 (1/2 HP, cast iron, the most commonly recommended contractor-grade pump in Ontario). Float: vertical switch (not tethered — vertical switches do not get stuck). $340 supply, $280 plumber install.
  2. Battery backup system: Basement Watchdog BWSP with a Group 27 deep-cycle marine battery. Activates on both power failure and primary pump failure (it monitors the water level independently). Backup capacity: approximately 1,200 GPH for 5-7 hours. $320 supply, $180 install.
  3. Wi-Fi water sensor: Govee H5054 in the sump basin and a second one in the utility area of the basement. $45 each. Sends smartphone alerts if water detected anywhere on the floor.
  4. Discharge line improvement: Discovered our 1.5-inch discharge was undersized — it created back-pressure that shortened motor life. Re-ran in 1.75-inch pipe, added a check valve (our previous install had none — every time the pump shut off, water drained back into the pit, forcing the pump to restart constantly). $280 plumber.
Total system cost: $1,465 installed.
If we had the battery backup and water sensor before the failure, we would have gotten an alert while the basin was filling, caught it before overflow, and paid $465 for a new pump instead of $1,000 deductible plus weeks of rebuild work.
