Ontario Window Replacement 2026: Vinyl vs. Fibreglass vs. Wood — The Honest Comparison
Window Replacement in Ontario 2026: The Real Material Comparison
After replacing windows in hundreds of GTA homes, here’s the honest breakdown.
Vinyl Windows
Cost: $350–$850/window installed (standard sizes)
Lifespan: 20–30 years
The most common choice. Modern vinyl has improved significantly. Multiple chambers, better UV stabilization, better hardware than 1990s product.
Pros: Lowest cost, zero maintenance, good thermal performance
Cons: Limited colour options, expands/contracts noticeably in GTA extremes (-25°C to +35°C), not ideal for heritage homes
Best for: Budget renovations, rental properties, non-heritage homes
Fibreglass Composite Windows
Cost: $650–$1,400/window installed
Lifespan: 25–40+ years
The best performing frame for Ontario’s climate. Fibreglass expands/contracts at nearly the same rate as glass — seals stay intact longer.
Pros: Superior longevity, paintable, excellent thermal performance, holds up in freeze-thaw cycles
Cons: Higher cost, fewer Ontario suppliers
Best Ontario brands: Inline Fiberglass (made in Ontario), Marvin, Pella
Wood / Wood-Clad Windows
Cost: $900–$2,500+/window
Lifespan: 40+ years if maintained
Wood interior, aluminum or fibreglass exterior cladding. Required in many heritage character areas.
Pros: Premium aesthetics, paintable interior, excellent longevity, rebate-eligible
Cons: Highest cost, wood interior requires care
Energy Performance (Rebate Eligibility)
  • Look for ENERGY STAR certification (required for Greener Homes grant)
  • ER (Energy Rating) of 34+ qualifies for federal rebates
  • Triple pane for north-facing or high-exposure installations
Post your window replacement experiences below — brand, installer, and how they’ve performed over time.
LF Builders handles window replacement as part of exterior packages: lfbuilders.ca
home.renovation.reviews | Samm Simon 251 KM: sammsimon.ca
