Ontario Vinyl Siding Installation and Replacement Guide 2026
Vinyl Siding Installation and Replacement Guide for Ontario Homes 2026
Vinyl siding is one of the most popular exterior claddings in the GTA — low maintenance, durable, and affordable. Here is what you need to know about grades, installation, and Ontario climate performance.
Vinyl Siding Grades
Grade Thickness Cost per Sq Ft
Entry-grade 0.040" $4-8
Residential (most common) 0.042-0.044" $6-12
Premium/architectural 0.046-0.055" $10-18
Insulated (foam backing, R-2 to R-3) Variable $12-22
Ontario OBC Installation Requirements
  • Building permit required for full replacement
  • House wrap or drainage plane behind siding (mandatory in new construction, strongly recommended in retrofits)
  • 1/4-inch minimum gap for drainage
  • Nail hem must be loose — vinyl must float to expand and contract with temperature. Nailed tight = buckling in GTA summer heat.
Colour Selection Warning
Dark colours (LRV below 55) can cause warping on south/west-facing walls. Most manufacturers void warranties on dark colours without their specific dark-colour product line. Light grey, beige, and white carry the fewest climate risks.
Complete Installation Scope
Full replacement includes: J-channel at windows/doors, corner posts, vented soffit panels, fascia covers, utility trim at foundation, and frieze board. Trim quality and fit determines overall appearance.
Cost Guide (2-Storey Home, 2,000 Sq Ft Siding)
Type Installed Cost
Residential grade vinyl $14,000-28,000
Premium insulated vinyl $24,000-44,000
Includes house wrap, trim, and disposal of existing siding.
Find GTA siding contractors on home.renovation.reviews.
LF Builders installs vinyl and other exterior claddings across the Greater Toronto Area. lfbuilders.ca
