Ontario Smart Home Wiring During Renovation: Cat6, In-Ceiling Audio & Smart Switch Prep
A renovation is the single best time to add smart home infrastructure at minimal cost. Here is what Ontario homeowners should plan during framing stage.
Run Cat6 Ethernet Everywhere
Wire every bedroom, office, living area, and media location with Cat6 ethernet. Wired is faster, more reliable, and lower latency than WiFi for gaming, video conferencing, and streaming. Cost during framing: $50-$150/drop — trivial compared to retrofitting through finished walls.
In-Ceiling Speaker Pre-Wire
Pre-wire speaker cable during framing. Add speakers at any point later. Pairs with Sonos, Denon HEOS, Bluesound. Cost: $75-$200/location during rough-in vs significantly more through finished ceilings.
Smart Switch Neutral Wire
Specify neutral wire at all switch locations. Deep electrical boxes. Smart switches (Lutron Caseta, Leviton Decora Smart, Insteon) require neutral wire in most cases. Standard boxes without neutral create compatibility issues.
Motorized Blind Pre-Wire
Motorized blind systems (Hunter Douglas PowerView, Lutron Serena) need specific pocket dimensions and low-voltage wiring at window headers. Plan during framing — retrofitting is invasive and expensive.
Structured Wiring Panel
Centralise all incoming coax, ethernet, and low-voltage wiring in a structured wiring panel (typically in utility room or basement). Makes future troubleshooting and upgrades clean. Cost: $500-$1,500 installed.
Discuss smart home integration and find Ontario low-voltage contractors at home.renovation.reviews.
