Ontario Roofing Material Comparison and Replacement Guide 2026
Replacing a roof is a major investment. Here is how all major roofing materials compare on performance in GTA climate conditions and 2026 installed costs.
GTA Roofing Challenges
The GTA climate subjects roofs to: 45+ freeze-thaw cycles/year, ice dam risk, UV degradation, wind uplift, and heavy snow loads. The best Ontario roofing materials address all of these.
Material Comparison
Material Lifespan GTA Climate Installed Cost
3-tab asphalt 20-25 yr Adequate $5-8/sq ft
Architectural asphalt 30-50 yr Good $7-11/sq ft
Class 4 impact asphalt 30-50 yr Very good $9-14/sq ft
Standing seam metal 50+ yr Excellent $15-25/sq ft
Steel shingle 50 yr Excellent $12-20/sq ft
Cedar shakes 25-35 yr Good (with maintenance) $12-20/sq ft
Synthetic slate/shake 50 yr Excellent $18-30/sq ft
OBC Ice and Water Shield Requirements
Minimum 900mm (3 ft) from exterior wall up slope. Extends to 600mm inside heated space in ice dam zones. This is mandatory — do not accept a bid without ice and water shield.
Ventilation Requirements
Minimum 1:300 NFA ratio (1:150 for balanced systems). Ridge vent + soffit vent combination is most effective for GTA ice dam prevention.
Building Permit
Required for roof replacement in most Ontario municipalities.
Cost Guide (1,800 sq ft home)
Type Total Cost
Architectural shingles (tear-off + replace) $12,000-20,000
Standing seam metal $27,000-45,000
Synthetic slate/shake $32,000-54,000
Find GTA roofing contractors on home.renovation.reviews.
LF Builders has replaced roofs across the GTA for over 50 years. lfbuilders.ca
