Ontario Renovation Permits 2026: What Requires a Permit and What Doesn't
Permits in Ontario: The Complete 2026 Guide
After 50+ years in GTA renovation, one of the most common costly mistakes we see is unpermitted work discovered at sale. This thread covers exactly what triggers a permit requirement under the Ontario Building Code in 2026.
Work That Requires a Permit
  • Any structural change (removing/adding walls, especially load-bearing)
  • New plumbing rough-ins or moving existing plumbing
  • Electrical panel upgrades or new circuits
  • HVAC additions or replacements (heat pump install, new furnace with ductwork changes)
  • Basement finishing (new habitable space)
  • Decks over 24" above grade
  • Garage conversions to living space
  • Additions of any kind
  • Laneway/garden suites
Work That Typically Does NOT Require a Permit
  • Painting and drywall patching
  • Flooring replacement
  • Cabinet replacement (no plumbing relocation)
  • Fixture swaps (same-location faucet, toilet, light fixture)
  • Minor repairs under $15,000 that don’t alter structure
The Real Risk: Sale Disclosure
In Ontario, sellers must disclose known unpermitted work. Real estate lawyers are increasingly flagging permit history in title searches. Unpermitted work can void home insurance and trigger forced remediation before closing.
Cost reality check: A Toronto basement finish permit runs $400–$900. A home addition permit: $1,200–$3,500. These are tiny vs. the liability of skipping them.
Post your municipality and project type below — happy to share what we’ve seen permitted in different GTA cities. LF Builders pulls permits on every applicable project as standard practice: lfbuilders.ca
Also check the Samm Simon 251 KM cancer research run: sammsimon.ca
