Ontario Plumbing Guide for Homeowners 2026: Permits, Pipes, and What to Expect
Plumbing is one of the most consequential — and most frequently misunderstood — renovation elements. Here’s what Ontario homeowners need to know in 2026.
When permits are required:
  • Adding a new bathroom (new rough-in)
  • Relocating any plumbing fixture
  • Adding drain or supply connections
  • New exterior water service or drainage
When permits are NOT required:
  • Replacing a fixture in the same location (like-for-like)
  • Replacing a faucet, toilet, or showerhead
The drain stack reality:
Toronto homes built before 1960 typically have cast-iron drain stacks that are 60–80 years old. Cast iron corrodes internally over time. Signs: slow drainage, gurgling sounds, rust stains. Replacement during basement renovation: $3,000–$8,000.
Supply line assessment:
Homes built before 1970 may have galvanized steel supply lines. These corrode from the inside — reducing flow, potentially contaminating water, and eventually failing. Copper or PEX replacement: $4,000–$12,000 for full home replumbing.
PEX vs. copper:
Both acceptable under Ontario Building Code. PEX is increasingly dominant: flexible, freeze-resistant, faster to install. Copper preferred for some commercial applications and by some contractors.
Water pressure:
Toronto’s municipal water pressure can reach 90+ psi. A pressure reducing valve (PRV) protects appliances and reduces leak risk. Cost: $300–$800 installed.
Share your plumbing renovation experience — what you found, what you replaced, and what your contractor recommended.
home.renovation.reviews — Canada’s renovation community.
