Ontario Laneway and Garden Suite 2026: Costs, Zoning, and Rental Income Reality
Laneway and Garden Suites in Ontario 2026: The Complete Development Guide
Ontario’s intensification push has made secondary suites viable for more homeowners than ever. Here’s the complete picture for 2026.
Laneway Suite vs. Garden Suite
Laneway suite: Fronts onto a public rear laneway. Vehicle access possible. Common in pre-1960 Toronto neighbourhoods (Annex, Leslieville, Riverdale, etc.)
Garden suite (ADU): Set within the rear yard, no laneway access required. Toronto’s 2022 bylaw opened nearly all residential zones to garden suite development.
Toronto Zoning Rules (2026)
  • Maximum 40% rear yard lot coverage (or footprint of main house, whichever is less)
  • Maximum 6m building height (two storeys possible)
  • Minimum 1.5–7.5m rear yard setback depending on zone
  • Lot minimum typically 7.5m wide
Utility Connections: The Cost Wildcard
  • New water service from street + sanitary connection: +$20,000–$50,000
  • Extension from existing house service (if feasible): significantly lower
  • Electrical: shared from main house or separate metering (separate preferred for rental)
Check with City of Toronto/your municipality’s utility connection requirements before finalizing your budget.
2026 Full Build Costs (Toronto)
Suite Type Cost Range
Laneway suite, 1-bed (~500 sq ft) $280,000–$380,000
Laneway suite, 2-bed (~700 sq ft) $340,000–$480,000
Garden suite, 1-bed $250,000–$360,000
Includes architecture, permit, construction, utility connections
Rental Income Reality (Toronto 2026)
  • 1-bed suite: $2,200–$3,500/month depending on location and finishes
  • Simple payback (construction cost ÷ annual rent): 8–14 years before appreciation
LF Builders has completed suite projects across Toronto: lfbuilders.ca
Active laneway/garden suite discussions: home.renovation.reviews
Samm Simon 251 KM for cancer: sammsimon.ca
