Ontario Kitchen Lighting Guide: Pot Lights, Under-Cabinet LED & Electrical Requirements
Planning kitchen lighting in Ontario? A well-lit kitchen requires layered lighting: ambient, task, and accent. Here is what Ontario homeowners need to know.
Pot Light Layout
A standard rule is one pot light per 4-6 sq ft of ceiling area. Space them 2 feet from walls and 4 feet apart on centre. For a 10x12 kitchen, 6-8 pot lights are typical. Use IC-rated (insulation contact) fixtures if insulation is above.
Under-Cabinet LED
Under-cabinet LED strips or puck lights eliminate countertop shadows. Look for 2700K-3000K colour temperature for warm task lighting. Hard-wired is cleaner than plug-in; run cable in the wall before backsplash installation.
Electrical Requirements in Ontario
Under the Ontario Electrical Safety Code, kitchen lighting circuits are typically on 15A breakers. Adding pot lights or under-cabinet circuits usually requires a licensed electrician and an ESA permit. Budget $800-$1,800 for a full kitchen lighting upgrade including permit.
Dimmer Compatibility
LED dimmers are not universal. Match the dimmer to the LED driver specs. Trailing-edge dimmers work best for most LED pot lights. Test one fixture before committing to the whole run.
Colour Temperature
2700K: warm, restaurant-like feel. 3000K: crisp task lighting. Mix zones if you want warm ambiance at the island and bright task light over the sink.
Discuss your kitchen lighting project with Ontario renovation contractors at home.renovation.reviews. Share your layout questions, get permit advice, and find licensed electricians for your GTA kitchen reno.
