Ontario Garage Conversion and Addition 2026: Rules, Permits, and Costs
Garage Conversions and Additions in Ontario 2026
Attached Garage Conversion to Living Space
Requires a permit in all Ontario municipalities.
Key code requirements:
  • Insulation to current OBC standards (minimum R-20 walls, R-40 ceiling for heated space)
  • Vapour barrier on all exterior walls
  • Damp-proofing / moisture barrier on concrete slab
  • Electrical upgrade to habitable space standard
  • Egress window in any bedroom created
Cost: $45,000-$100,000 for full conversion to quality living space.
Zoning Caution: The Parking Rule
Many GTA municipalities require minimum on-site parking per dwelling unit. Converting your only attached garage to living space may violate parking requirements. Check zoning BEFORE planning.
Some areas permit conversion if a parking pad remains. Others require Committee of Adjustment variance. This is the most common regulatory surprise in garage conversion projects.
Detached Garage Addition
Permit required in most Ontario municipalities if over 55 sq m.
Costs (installed, basic):
  • Single-car detached: $30,000-$60,000
  • Double-car detached: $50,000-$95,000
  • Above-garage ADU suite: $180,000-$280,000 (garage + 1-bed suite)
The above-garage ADU option is increasingly popular in Toronto – adds rental income ($1,800-$2,400/month) while preserving parking.
Value Reality
A properly converted garage adds living square footage at relatively low cost per sq ft vs. a full addition – but only when permitted and code-compliant. Unpermitted garage conversions are a significant liability at sale.
LF Builders handles garage conversions across the GTA: lfbuilders.ca
home.renovation.reviews | Samm Simon 251 KM: sammsimon.ca
