Ontario Flat Roof Replacement and Repair Guide 2026: Systems, Drainage, and Costs
Flat roofs are common on Toronto row houses, commercial properties, and additions. Ontario’s freeze-thaw cycle makes maintenance critical. Here is what you need to know.
Flat Roof Systems Compared
System Lifespan Cost per Sq Ft
Modified bitumen (2-ply) 15-25 yr $8-15
TPO single-ply 20-30 yr $9-16
EPDM single-ply 20-30 yr $8-14
Built-up roofing (BUR) 20-30 yr $10-18
Green/vegetative roof 30+ yr $20-50+
Most common in GTA residential: Modified bitumen (SBS rubber-modified asphalt).
Drainage is the Critical Factor
Flat roofs require minimum 1:50 (2%) slope to internal drains or scuppers. Ponding water (standing 48+ hours after rain) accelerates membrane deterioration and violates OBC. Solutions: tapered insulation (crickets), additional drains, or saddles.
Where Failures Originate
90% of flat roof failures are at flashings, not field membrane:
  • Parapet cap flashing (metal coping or membrane over parapet)
  • Base flashing (minimum 200mm above roof surface)
  • Penetration flashings (drains, vents, HVAC equipment)
Inspect and recaulk all penetrations annually.
Ontario Building Code
Building permit required for flat roof replacement. Recover (new over old) limited to one layer — second recover requires full tear-off. Minimum insulation: R-31 effective.
Cost Guide (1,000 sq ft)
Scope Cost
Modified bitumen 2-ply $8,000-15,000
TPO with rigid insulation $9,000-16,000
Full tear-off + insulation upgrade Add $2,000-5,000
Annual maintenance and inspection $400-800
Find GTA flat roof contractors on home.renovation.reviews.
LF Builders installs and maintains flat and low-slope roofing across the GTA. lfbuilders.ca
