Ontario Electrical Renovation 2026: K&T, Aluminum Wiring, Panels, and ESA
Ontario Electrical 2026: What Your Home’s Wiring Era Means
Knob-and-Tube Wiring (Pre-1950)
Most Ontario insurers won’t insure homes with active K&T. No ground conductor. Open air wiring system.
Cost to replace: $12,000-$25,000 for a typical GTA home.
Required before any major renovation – you can’t insulate over K&T without creating a fire risk.
Aluminum Wiring (1960s-1970s)
Not inherently dangerous if properly managed. Problem: oxide layer at connections + expansion/contraction rate.
Solution 1 – Pigtailing: Connect aluminum runs to short copper pigtails at every device using approved connectors (Ideal 65 or AlumiConn). Cost: $3,000-$10,000. ESA-accepted.
Solution 2 – Full replacement: $8,000-$18,000. Complete peace of mind.
Panel Upgrades
Upgrade Cost
60A → 100A $1,500-$2,500
100A → 200A $2,500-$4,500
200A → 400A $4,500-$8,000
200A recommended before adding EV charger or cold-climate heat pump.
All panel work requires ESA permit + inspection in Ontario.
EV Charger Rough-In
Level 2 (240V, 40-50A dedicated circuit): $800-$1,800 installed.
Do this during renovation – costs 3-4x more after walls close.
AFCI/GFCI Requirements (Current OBC)
  • GFCI: within 1.5m of any water source
  • AFCI: bedrooms (and expanding with each code update)
LF Builders coordinates electrical within all GTA renovation scopes: lfbuilders.ca
home.renovation.reviews | Samm Simon 251 KM: sammsimon.ca
