Ontario Attic Conversion to Loft or Living Space 2026: OBC Guide
Converting Your Ontario Attic to Living Space in 2026
An attic conversion can add 15-30% more usable floor area to an Ontario home without expanding the footprint. But it’s one of the most complex residential projects in the OBC’s scope. Here’s what you need to know.
Is Your Attic Convertible?
Key criteria:
  • Headroom: Minimum 2.1 m (6 ft 11 in) over at least 50% of the floor area (OBC habitable space requirement)
  • Structural capacity: OBC minimum 1.9 kPa (40 PSF) live load for bedrooms — most attic joists are not designed for this
  • Stair location: Adequate space for a code-compliant staircase (minimum 860mm/34 in width, maximum 8.25-inch rise)
Get a structural engineering assessment before committing.
Structural Upgrades Typically Required
  • Sister joists (new lumber alongside existing)
  • Engineered LVL beams replacing undersized members
  • Structural ridge beam (if removing load-bearing collar ties)
Budget: $5,000 - $20,000 for structural work alone.
Insulation Strategy
Moving thermal boundary from floor to roof:
  • Spray foam on roof deck underside: R-30 to R-40, unvented assembly
  • Rigid foam + batt in rafter bays: Vented assembly
  • OBC minimum: R-31 for roofs. Recommended: R-50 to R-60 for Ontario climate.
Egress Requirements
Any attic bedroom requires:
  • Minimum 0.35 m² clear opening
  • Maximum 1.0 m sill height from finished floor
  • Typically achieved via dormer window
Dormer addition cost: $25,000 - $60,000.
Permit Requirements
All attic conversions require a building permit. Change of use triggers full OBC compliance review. Plan for 4-6 inspections from rough framing to final occupancy.
Cost Ranges
Scope Cost
Simple loft (no bathroom, no dormer) $45,000-90,000
With dormer and full bathroom $90,000-180,000+
Per sq ft (finished) $200-450
Connect with Ontario attic conversion specialists on home.renovation.reviews.
LF Builders has managed complex attic and loft conversions throughout the GTA since 1974. lfbuilders.ca
