Lot Grading Problems Ontario - Wet Basement Cause & Drainage Solutions
After spending $12,000 on interior waterproofing that barely helped, I finally had a drainage specialist look at my grading situation. Sharing this so others don’t make the same mistake.
The Root Cause I Missed
My Toronto home had negative grading on two sides - the soil had settled toward the foundation over 50 years. Every heavy rain, water was being directed straight to my basement walls. No interior drain tile system fixes that.
Ontario Standard
Minimum slope is 1 inch per foot for the first 6 feet away from the foundation. My lot was actually sloping TOWARD the house by about 2 inches over 6 feet - so there was a 3-inch swing between required and actual.
What Was Done
  • Excavated soil 3 feet out from foundation on two sides
  • Added clean fill topsoil and regraded to proper slope
  • Extended all downspout extensions to 8 feet
  • Added two catch basins in low spots at the back
  • Resodded grading areas
Total cost: $4,800 for the grading work. The interior system I had installed first was $12,000 and did not solve the actual problem.
Lesson Learned
Fix the exterior drainage first. Always. Interior drainage is a band-aid if you still have negative grading directing water to the foundation.
Signs You Have This Problem
  • Water pools against foundation walls after rain
  • Damp or wet basement within 24-48 hours of heavy rain
  • Soil that stays boggy near the house
  • Efflorescence (white chalky deposits) on basement walls
Anyone else dealt with this? What was your approach?
