Level 5 drywall finish in our Caledon master bedroom: what it looks like, what it cost
We completely rebuilt our master bedroom after an ice dam water damage incident. New ceiling, new walls, fresh start. Our designer specified Level 5 drywall finish and I am glad we listened.
Background: Our bedroom has a large south-facing window. In winter morning light, that sun hits the west wall at a very shallow angle — raking light that reveals every imperfection. Our previous Level 4 finish (not damaged, just painted over) showed every taped joint as a subtle stripe in morning sun. It never bothered us until we knew what to look for.
What Level 5 involves in practice:
After hanging new drywall (5/8 inch — we went with Type X for the ceiling after the water damage revealed the previous ceiling was 1/2 inch), the finisher did:
  1. Tape coat (mesh tape, setting compound) on all joints
  2. Second coat (all-purpose compound, feathered 8-10 inches)
  3. Third coat (all-purpose, feathered 10-12 inches)
  4. Fine sand
  5. Full skim coat — thin coat of all-purpose compound over every square inch of every surface, feathered to near zero at original drywall face
  6. Fine sand of full surface
  7. Primer — critical before Level 5 paint: PVA drywall primer seals the skim coat uniformly
  8. Paint — Benjamin Moore Regal Select in eggshell
The result: Under the raking winter sun, the walls are genuinely flat. Not a joint visible. The light just… slides across the wall with no interruption.
Cost: The finisher charged us $4.20/sqft for Level 5 vs $2.40/sqft for Level 4 that was standard on the rest of the main floor renovation. For our 240 sqft bedroom (approximately 360 sqft of wall surface), the premium was $648.
Verdict: Worth it completely in this room. I would not specify Level 5 for a basement or interior bathroom where raking light is not an issue — but for any room with significant natural light or where paint sheen matters, Level 5 is the only honest spec.
