Kitchen Island Planning: What Toronto Homeowners Get Wrong
Kitchen islands have become so standard in Toronto renovations that people assume any kitchen can have one. Having been through two kitchen renovations and helped friends through three more, here are the mistakes I see repeatedly.
Mistake 1: Island Too Small to Be Useful
The minimum useful island size is 4 feet long × 2.5 feet wide. Anything smaller is just another surface to pile mail on. If your kitchen can only accommodate a 3-foot island, consider a butcher block cart instead.
Mistake 2: Not Enough Clearance
The golden rule: 42 inches minimum clearance on all working sides of the island (48 inches preferred if two cooks, or if the island has appliances). This is where most Toronto renovations compromise — the kitchen looks great in the rendering but is a traffic jam in real life.
Mistake 3: Seating That Doesn’t Work
Seating at an island requires overhang for knees (12–15 inches) and appropriate stool height for the counter height. A standard 36" counter needs 24" stools. A raised 42" eating bar needs 28–30" stools. Measure before you buy.
Mistake 4: No Electrical
An island without electrical outlets is a missed opportunity. Ontario code now requires at least one duplex outlet per island. Plan for two. If your island will have a cooktop, the electrical and gas requirements change significantly.
Mistake 5: Seams in the Wrong Place
If your island countertop requires a seam (large islands do), place it away from the primary prep zone. A seam in the middle of your working surface will bother you daily.
For kitchen design resources and contractor recommendations in Toronto, home.renovation.reviews has active threads with photos from dozens of Toronto kitchen renovations.
