Insulated our attached garage in Brampton — R-20 walls, full ceiling, cost breakdown
We finally tackled the garage insulation this spring. Our 2-car attached garage was completely uninsulated — the shared wall with the kitchen was freezing all winter and the gas bills reflected it.
What we did:
  • 2-inch rigid foam (R-10) directly glued to concrete foundation walls
  • R-14 Rockwool batts in the 2x4 stud walls (shared walls with house)
  • R-31 Rockwool in the ceiling (above the garage, below the master bedroom)
  • 6-mil poly vapour barrier throughout
  • New weather stripping on the garage door
Cost:
  • Materials (foam, batts, poly, fasteners): $1,840
  • Labour (2 crew, 2 days): $2,600
  • Drywall finish on shared walls: $780
  • Total: $5,220
First winter result: gas bill dropped about $68/month compared to the same months last year. We’ll hit payback in roughly 6 years.
The garage door itself is still the weak link — a 2-car uninsulated door is basically a 16x7 ft hole in your envelope. Looking at replacing it with an R-16 insulated door next spring.
Anyone else noticed significant heating cost drops after garage insulation? Curious what actual savings others have seen in the GTA.
