Installed a hot tub in our Oakville backyard: permits, electrical panel upgrade, full cost
We finally pulled the trigger on the hot tub we have been talking about for three years. Oakville detached, 2003 build, decent backyard. Total cost ended up being $21,400 all in. Here is the full breakdown.
The hot tub: We went with a Beachcomber 570 (7-person, 71 jets). Supply only from the Burlington dealer: $14,200 including delivery and crane placement (our gate is too narrow to roll it in).
Electrical: This is where it got expensive. Our 100-amp panel was maxed out — every circuit had something on it. The hot tub needs a dedicated 50-amp 240V circuit with GFCI breaker and a disconnect box within sight. Electrician quoted us panel upgrade to 200-amp plus the hot tub circuit: $4,100. Permit and ESA inspection included. Took two days — one for the panel, one for the circuit run.
Concrete pad: We poured a 10x10 reinforced pad, 5 inches thick to handle the 3,800 lb loaded weight. Concrete contractor: $1,800. We had to wait three weeks for a spot — summer backlog.
Oakville permits: The town requires a building permit for any hot tub plus a separate electrical permit. Building permit was $210, took 11 days to come back. They inspect the fence/safety cover after installation.
Safety cover and fencing: Our existing fence is 5 feet, which meets Oakville’s requirement. The locking cover that came with the tub satisfies the secondary barrier requirement.
Total: $14,200 (tub) + $4,100 (electrical) + $1,800 (pad) + $210 (permit) + $180 (misc) = $20,490. Close enough to $21,400 with taxes on the permit.
Running costs: Hydro is up about $90/month in winter, $50 in summer. Worth it. We use it 3-4 times a week.
Anyone else in Halton Region navigate the hot tub permit process? Curious how other municipalities compare.
