How to Paint a Room Like a Professional: Ontario Contractor Techniques
Painting is the one renovation task most Ontario homeowners attempt themselves — and the results are often noticeably amateur. Professional painters produce results that look different because they follow a preparation and technique discipline that most DIYers skip.
The 80/20 Rule of Painting
80% of professional painting quality comes from preparation. The actual painting is the fast part.
Preparation: The Professional Approach
Step 1: Assess the substrate
Before buying paint, assess what you’re painting. New drywall needs different prep than walls that have been painted 10 times. Oil-based paint requires shellac primer before painting over with latex. Glossy surfaces need sanding or a bonding primer.
Step 2: Repair
Fill nail holes and minor cracks with lightweight spackling. For larger holes, use setting-type compound. Sand smooth, prime the repairs, and sand again before painting. Professionals reprime bare drywall after sanding — this catches absorptive spots that would show through paint.
Step 3: Clean
Wash walls with TSP (trisodium phosphate) or TSP substitute, especially in kitchens and high-traffic areas. Grease and residue cause adhesion failures and sheen differences.
Step 4: Tape and protect
Professional painters use 1.5" to 2" painter’s tape at trim lines, applied with a putty knife to eliminate gaps. Drop cloths cover floors — cloth, not plastic (plastic is slippery and causes accidents).
Cutting In: The Key Skill
“Cutting in” — painting edges along trim, ceilings, and corners — is the skill that separates professional results from amateur ones.
Professional technique: Use a 2.5" angled brush. Load it properly (1/3 to 1/2 the bristle length). Cut a “bead” line 1/4" from the tape or trim, then feather to the tape. Keep a wet edge. Don’t let cuts dry before rolling adjacent areas — this creates visible lap marks.
Rolling: Consistent Technique
Use a proper roller nap: 3/8" for smooth surfaces, 1/2" for typical drywall, 3/4" for textured surfaces. Apply paint in a W or M pattern, then fill in. Work in sections, maintaining a wet edge. Two thin coats always beat one thick coat.
Ontario-Specific Note: Humidity
Ontario’s spring and fall humidity can affect paint drying and final sheen. Avoid painting when humidity exceeds 85% or temperature is below 10°C. Open windows in summer only if humidity is low.
Painting tips, contractor recommendations, and product reviews at home.renovation.reviews — Canada’s renovation community.
