How to Install a Tile Backsplash: Complete GTA Kitchen DIY Guide
Tile backsplashes are one of the most rewarding DIY kitchen projects — visible impact, manageable skill curve, and costs that are primarily material rather than labour.
Materials You’ll Need
  • Tiles (see sizing notes below)
  • Tile adhesive / mastic (for vertical surfaces, pre-mixed mastic works well for most tile types under 12x12; use thinset for larger tiles or natural stone)
  • 1/16" to 1/8" tile spacers
  • Grout (unsanded for joints under 1/8", sanded for wider joints)
  • Grout sealer
  • Tile cutter or wet saw
  • Notched trowel (3/16" V-notch for small tiles, 1/4" square-notch for larger)
  • Grout float
  • Level
Step 1: Prep the Surface
Clean the wall thoroughly — no grease, dust, or loose paint. Drywall must be in good condition. In wet areas, use cement board or moisture-resistant drywall (Kerdi Board is excellent).
Mark a level horizontal reference line at your starting point.
Step 2: Lay Out the Pattern
Dry-fit tiles before adhesive. Find your centre point, work outward. This prevents awkward cuts at visible ends.
Step 3: Apply Adhesive
Work in 3–4 square foot sections. Back-butter each tile in addition to the wall for large-format tile. Don’t let adhesive skin over before setting tiles.
Step 4: Set Tiles
Press firmly with slight twisting motion. Check level frequently. Use spacers consistently.
Step 5: Grout
Wait 24 hours after setting. Remove spacers. Mix grout to peanut butter consistency. Work diagonally across tiles. Clean haze with damp sponge within 15 minutes. Final polish with dry cloth.
Common Mistakes
Grouting too soon: Adhesive needs 24 hours minimum. Skipping sealer: Natural stone and unglazed tile must be sealed before and after grouting. Cutting outlet holes inaccurately: Measure twice, score four times.
Post your project photos at home.renovation.reviews — GTA DIYers share before/after backsplash projects regularly.
