Home Office Conversion Complete — Scarborough Garage to Studio Office
Finished our garage-to-home-office conversion in Scarborough and wanted to document for anyone considering the same.
The space: Single-car attached garage, 220 sq ft, concrete slab floor, 7’8" ceiling height. Had been used for bikes, lawn equipment, and general storage.
The project:
  1. Insulated all walls (2x4 stud walls + R14 batt, then ½" drywall)
  2. Insulated ceiling (R30 above the ceiling between joists)
  3. Insulated slab (1" EPS rigid foam + ¾" plywood subfloor on top)
  4. Added mini-split (Mitsubishi 9000 BTU) for heating and cooling
  5. New electrical (2 circuits — one for the mini-split, one for outlets/lighting)
  6. Pot lights + task lighting (4 pot lights on dimmer)
  7. Hardwired ethernet (ran cat6 from the main panel chase)
  8. LVP flooring on top of the plywood subfloor
  9. Painted drywall (light greige — needed the brightness)
  10. Replaced garage door with a framed wall + single fixed window (double-glazed, wood-frame exterior)
ESA permit: Yes. The mini-split dedicated circuit required it. No building permit required since we weren’t changing the footprint or use classification.
Cost:
  • Insulation + drywall: $3,200
  • Electrical (mini-split circuit + outlets + lighting): $3,800
  • Mini-split (supply + install): $3,400
  • Subfloor + LVP: $2,100
  • Wall fill + framing (replacing garage door opening): $2,800
  • Pot lights + fixtures: $400
  • Cat6 + patch panel: $350
  • Painting: $600
Total: $16,650
It’s one of my favourite rooms in the house. Two dedicated desks, completely acoustically separated from the living area, and temperature-controlled year-round.
7’8" ceiling feels fine — not low at all for a work environment. The window does a lot to prevent it feeling cave-like.
