Heated Driveway Systems Ontario - Electric vs Hydronic, Costs & Permits
If you’re tired of shovelling and salting every winter, a heated driveway system might be worth the investment. I did a lot of research before going the hydronic route last fall, here is what I learned for Ontario homeowners.
Electric vs Hydronic - Key Differences
Electric systems use resistance cables embedded in concrete or asphalt. They are cheaper to install ($12-20/sq ft) but more expensive to run given Ontario TOU electricity rates. Hydronic systems circulate a glycol/water mix through PEX tubing connected to a boiler. Higher upfront cost ($18-30/sq ft installed) but lower operating costs, especially if you already have a natural gas boiler for in-floor heating.
Typical Costs in the GTA
For a 500 sq ft double driveway expect:
  • Electric: $8,000-$15,000 installed
  • Hydronic: $10,000-$18,000 installed
New construction is significantly cheaper since the system is installed during the pour. Retrofit (removing existing driveway) adds $2,000-$4,000 for demolition.
Permits Required
Electrical permits required in Toronto, Mississauga, Brampton for hardwired systems. Hydronic tied to boiler may also require a mechanical permit. Always check with your local building department.
Smart Controls Are Essential
Automatic precipitation + temperature sensors can cut operating costs by 40-50% vs manual operation. Look for systems with remote monitoring via app so you can control it when you are away.
Anyone else in Ontario run these systems? Would love to hear about operating costs across different winters.
